Tire size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gingabread, Feb 25, 2021.
  1. Feb 25, 2021 at 10:08 AM
    Gingabread
    Gingabread [OP] Well-Known Member
    2020 gray TRD Off road
    Hello all,
    I was looking at upgrading my tires from the factory ones. It looks like the Falcon wildpeak a/t3w is a pretty solid tire.
    I wanted to see if any one knows what the biggest size I could go with out rubbing and standard suspension for trd off-road.
    I know I won’t be able to get a huge difference with out lifting it, but that will be some time down the road.
    thanks for tips!
  2. Feb 25, 2021 at 10:22 AM
    SDTaco19
    SDTaco19 Active Member
    2019 Tacoma TRD OR
    lots of threads on here about tire size so you’ll get a bunch of people saying “did you search other threads” haha just so you know. The stupid answer is “it depends”. Some people will say that you can fit 285s with some trimming on your own without rubbing and others will say absolutely not. Also everyone has an opinion on the brand of tire. The most common ones are the Falken, BFG, and Toyo in my opinion. On my truck, I personally went with Toyos and love them. I like the look and I am confident in them lasting after doing my research. It all comes down to watch you are comfortable with after doing some self research. There won’t be a “right” answer here! Lots of preferences which is the beauty of TW I guess!
  3. Feb 25, 2021 at 10:23 AM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    biggest width or biggest height?
  4. Feb 25, 2021 at 10:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Depends on the specs of the wheel you use.
    And which dimension of a tire you want to make 'bigger'.
    71tattooguy likes this.
  5. Feb 25, 2021 at 10:26 AM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    The short answer is 265/75/16 on the stock wheels
    The long answer is, you can go taller than this with skinny tires, or fatter with short tires, or neither with negative offset aftermarket wheels, and it takes some research.
    71tattooguy and Junkhead like this.
  6. Feb 25, 2021 at 10:37 AM
    evotacoma
    evotacoma Well-Known Member
    You can go with skinny tires. There is a thread on here with some really good feedback. You can get 33" tires with stock rim/suspension with no rub on a TRD OR. Size 255/85/16.
    Clearwater Bill and Junkhead like this.
  7. Feb 25, 2021 at 12:38 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    265/75/16 or 255/85/16 on stock OR rims.
  8. Feb 26, 2021 at 12:57 PM
    Giusejuice
    Giusejuice Well-Known Member
    South Florida / Boulder
    2020 MGM 6Spd OffRoad DCSB
    Eibach Lift | 33s
    Can personally recommend 255/85r16. Installed the Master craft CTX. pretty aggressive tries and they fit with no rub on stock OR rims. Lighter than 285s, extremely capable
    evotacoma likes this.
  9. Feb 26, 2021 at 1:01 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    255/85/16 is a pizza cutter. 265/75/16 ftw
    Superdave1.0 likes this.
  10. Feb 26, 2021 at 1:07 PM
    Giusejuice
    Eibach Lift | 33s
    But 2 inch shorter. your only benefit is a third of an inch in wideness and more contact patch to move. Have you had any rubbing on with 265s on stock suspension?
