Tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tanner.b16, Oct 5, 2022.
  1. Oct 5, 2022 at 1:45 PM
    Tanner.b16
    Tanner.b16 [OP] Well-Known Member
    Tanner
    South Carolina
    clean 07’ Tacoma
    Hey guys, Got some new wheels recently that are 16x8 with -12mm offset. Anyone know the biggest tires I can run on my 2nd gen? Thanks
  2. Oct 5, 2022 at 1:48 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    The real question, how fast do you want your tires to run?
  3. Oct 5, 2022 at 1:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The -12mm offset causes more rub, because the tire swings on a wider arc when steered. With no trimming? Stock size 265/70-16. With fender flare trimming, 265/75-16. With cab mount chop and pinch weld hammered, 285/75-16.
  4. Oct 5, 2022 at 9:51 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    :woot:Yip. What he said
  5. Oct 6, 2022 at 10:04 AM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    doesn’t matter
  6. Oct 6, 2022 at 10:05 AM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    I appreciate it man!
  7. Oct 6, 2022 at 10:06 AM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    and you’re 100% sure on this?
  8. Oct 6, 2022 at 10:15 AM
    mattrussmill
    mattrussmill Well-Known Member
    2015 SR5 DCSB
    If you don't believe him, the amount you fuck around is directly proportional to the amount you'll find out so you could also just buy tires and send it ;)
  9. Oct 6, 2022 at 11:11 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Stock height or lifted?
  10. Oct 6, 2022 at 11:19 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    You can run 40s
    :sawzall:
  11. Oct 6, 2022 at 11:21 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    The lift isn't going to change the tire size you can fit unless you use taller bump stops because when the suspension cycles you'll still be stuffing the tire into the same size opening.
  12. Oct 6, 2022 at 11:24 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Buy the biggest tire size you want and cut accordingly. The truck is getting on 16 years old, reaching the age of consent in most jurisdictions.
  13. Oct 6, 2022 at 11:45 AM
    DG92071
    DG92071 Well-Known Member
    Absolutely incorrect. There is more than one type of lift.
  14. Oct 6, 2022 at 12:14 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fair enough...I assume you're referring to spindle, DB, or body lifts. If it's a suspension lift where the height is from spacers or springs (which likely covers 90% of the lifts that people run) you'll have issues.
  15. Oct 6, 2022 at 12:41 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
  16. Oct 6, 2022 at 12:47 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    This is excellent. Reminds me of the Hot - Crazy matrix. Video below should be taught to all young men.
  17. Oct 6, 2022 at 12:49 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^I'm running 35s without a cab mount chop. That makes it a unicorn?
    mic_sierra[QUOTED] likes this.
  18. Oct 6, 2022 at 12:52 PM
    mic_sierra
    Elsewhere
    Above 35 with no CMC... careful man. You're talking to a Chevy.
  19. Oct 6, 2022 at 12:53 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Don't forget the pizza cutter crowd. 255/85/16 or 255/80/17 for some
    HuskerTrucker likes this.
  20. Oct 6, 2022 at 12:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^OP bought wheels already. With that offset, 285/75-16 will rub as bad as 255/85-16.
