Tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CHADD, Nov 5, 2024.
  1. Nov 5, 2024 at 6:04 AM
    CHADD
    CHADD [OP] Member
    I have a 2nd gen Tacoma with a 3in lift. Will 255 85 16 fit without rubbing?
    Any help would be grateful
    SethM likes this.
  2. Nov 5, 2024 at 7:02 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
  3. Nov 5, 2024 at 9:49 AM
    TacoTuesday1
    FL
    35’s is the minimum
    SethM likes this.
  4. Nov 5, 2024 at 11:07 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Can probably go 285/70/16
  5. Nov 5, 2024 at 11:23 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I ran them for several years: BFG KM3 255/85r16 with a 3" lift (Dobisons and Alcan.) Assuming you are using factory wheels-I had 3rd Gen OR rims, they will rub a little depending on your alignment. I deleted the mud flaps, but still had some rub at full stuff. Nothing in the back. PM if you need more
  6. Nov 5, 2024 at 2:00 PM
    badger
    badger Well-Known Member
    07 SR5
    Unfortunately, people are worn out answering this question, including me. There is a ton of info in the threads already referenced, so I suggest you do some reading. The answer is not as simple as you might think. Many factors come into play. I do think that this tire size is the perfect fit for a Tacoma, and I spend 7 months a year living and back country traveling alone in my truck. I have a manual transmission, 4:88 gears, 2.5" lift, 7.5" FJ Cruiser "beadlock" wheels, cab mount chop, and running a Dobinson's billet UCA with 2 degrees of caster offset, 3 degrees total caster. All of this stuff matters. If you read it all and still have a question, you can try here again, or PM me if no one responds. Good luck.
