Tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blade29, Nov 14, 2024.
  1. Nov 14, 2024 at 5:44 PM
    Blade29
    Blade29 [OP] Member
    Blake
    2011 Tacoma TRD Off Road
    Hey guys! I have a completely stock 2011 Toyota Tacoma. I was wondering if it’s possible to fit 285/70/R17’s without any type of lift kit. Thanks for any info you have!
  2. Nov 15, 2024 at 7:58 AM
    Flex-AZ
    Flex-AZ Well-Known Member
    Flagstaff, AZ
    2015 TRD Sport DCLB
    Camburg/Deaver mid travel
    You can bolt them on but depending on the offset/backspacing specs on your wheels you can expect a lot of rubbing in the wheel wells. If you just drive on the street you will notice it on turns and bumps. If you go off road you’ll notice the (extensive) problems right away. You could put bump stop extensions on which will help on the bumps (but not turns) but will also limit your travel.
