tire size?
Discussion in 'Wheels & Tires' started by trd4us, May 10, 2008.
  1. May 10, 2008 at 7:40 PM
    trd4us
    trd4us [OP] Active Member
    va
    08 trd and 2009 reg cab
    08 trd, daystar leveling kit, k&n fipk, 285/75/16 pro comp x terrains, spidertrax wheel spacers, flowmaster 40 series exhuast.the 2009 is stock only 130 miles
    anyone know if a 285/75/16 will fit with the daystar 2.5 front and 1.25 rear lift kit
  2. May 10, 2008 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What wheels? If stock wheel, you will rub the UCA as well as the fender liner. With after market wheels and/or new UCA's, you will just rud the fender liners and maybe the body mount. A little triming with a saw and you should be fine. :)
  3. May 10, 2008 at 8:44 PM
    trd4us
    va
    it is hard to take a saw to a trd with only 7000 miles but what ever works. thank for the info!
  4. May 13, 2008 at 8:36 PM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    what kind of saw does the cleanest trim?
