Tire Sizes for a 15" rim?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99tacosupreme, Dec 3, 2010.
  1. Dec 3, 2010 at 9:57 PM
    99tacosupreme
    99tacosupreme [OP] Well-Known Member
    Kyle
    Southern California
    1999 Black V6 PreRunner TRD
    Pioneer Headunit, Infinity Kappa 6.5" speakers, Alpine Type R sub with Alpine M500 amp, 15% Tint up front 5% in the back, Deckplate mod, Debadged, Bilstien 5100s, Wheelers 1.5"AAL, DDM 55w 6k Lights
    I am looking at new tires for my truck and I cant decide if I should stick with my current size of 31/10.5/15 or bump up to 32/11.5/15 Since I just installed my lift. First off will the 32/11.5/15 fit with out rubbing on my stock 15 alloy rim? I have a 2.5" lift with stock UCAs.
  2. Dec 4, 2010 at 7:45 AM
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    Subscribed.
    I'm in need of tires for winter & I'm torn between sticking with the 31's or bumping up to the 32's.
    I'm in the process of getting quotes from local shops for BFG A/T's in both of those sizes. I can't say for sure, but I believe you're gonna be okay with that lift/tire size combo.
    I honestly didn't know the 32/11.5/15 existed until a week ago when I saw them on a newer 1st Gen. (think it was an 01, looked like a 2.5 - 3" lift)
  3. Dec 4, 2010 at 7:56 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    32x11.5 is pretty much the same size as 285/75R16, so its very close on rubbing (which lots of people run). You may have to trim/pound in the seem (pinch weld) behind the tire. As far as on the frame, you will have rubbing at full lock unless you have less than default backspacing or spacers. A lot will depend on what wheels you have though, as 15x8 will hold the tire different than 15x10. If you only have a 15x7 wheel, you might run into issues with legit tire companies not wanting to put on a 11.5" wide tires on your wheel due to it exceeding recommended wheel/tire size. If you have front mud flaps, they'll pretty much have to go. Personally, if you're going to go to that much trouble, might as well go with 33s and call it good. There's a 33x10.5 that should fit a bit better than the 32x11.5, or you could do the extra work at go with the 33x12.5 for that more beefy look.
  4. Dec 4, 2010 at 11:12 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I've got 32x11.50's on my truck with 2.5-3" lift. Some minor pinch weld pounding was all that was needed. I'm running a 15x8" wheel. I'm not running the front mudflaps now but had them on for a long time with these tires and it was fine. I've had no rubbing issues at all with this size tire and this amount of lift.
    I'd go for the 32's no question.
  5. Dec 4, 2010 at 8:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    32x11.5/15s will fit and I really doubt you will see any rubbing at all with your lift. Especially since you will be running the stock whels with the stock offset/backspacing.
    Now 8" wide aftermarket wheels may cause a tiny bit of rubbing becasue the wheel sits a little further out.
  6. Dec 4, 2010 at 8:54 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Hey Digiratus, is that pic of your truck taken at Crater Lake?
  7. Dec 4, 2010 at 9:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yup. This past July.
  8. Dec 4, 2010 at 9:12 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
  9. Dec 5, 2010 at 9:17 AM
    99tacosupreme
    Kyle
    Southern California
    you mean 32s?
  10. Dec 5, 2010 at 11:07 AM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
