tire sizes with 2inch front leveling kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota4wd, Aug 3, 2011.
  1. Aug 3, 2011 at 7:30 PM
    Yota4wd
    Yota4wd [OP] Member
    Louisiana
    RIP-08 Base 4x4 offroad- got totaled:(
    bull bar, off road lights, red neon under hood, ultra maverick rims
    Im thinking about putting a 2inch front leveling kit on my 2008 Tacoma 4 door 4x4. I was wondering what was the biggest tire i could run without rubbing
    Yota4wd
  2. Aug 3, 2011 at 7:37 PM
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    im running a 265/75/16 on mine. a 285 would be a tight fit and near impossible unless u trimmed alot
  3. Aug 3, 2011 at 7:41 PM
    09WhiteTaco4x4
    09WhiteTaco4x4 Well-Known Member
    Washington
    2009 4x4 TRD Off-Road DC
    Removed mud flaps, Borla cat-back exhaust, AFE Pro-Dry S air filter
    Anybody running 275/70R16's or 275/65R17's with a 2" front lift? You can get both of these sizes in the BFG A/T's and was strongly considering going with one of these sizes if I could fit them without any trimming and just a front leveling kit (with mud flaps removed). These tires are about 1.5" smaller in diameter and almost half an inch narrower than a 285/75R16 tire.
  4. Aug 3, 2011 at 7:42 PM
    Yota4wd
    Yota4wd [OP] Member
    Louisiana
    what about somethin like a 285/70/16?
  5. Aug 3, 2011 at 7:43 PM
    09WhiteTaco4x4
    Washington
    Do you know of any tires that come in that size? I have been looking quite a bit lately and I personally have not seen that size.
  6. Aug 3, 2011 at 7:45 PM
    Yota4wd
    Yota4wd [OP] Member
    Louisiana
    i just looked on tire rack and didnt see anything
  7. Aug 3, 2011 at 7:46 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    a 285 is too wide itll rub the uca unless u get wheel spacers. 275/70 would look good its just not that common of a size. i think its been done though
  8. Aug 3, 2011 at 7:47 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I think you could make those work.
  9. Aug 3, 2011 at 7:49 PM
    09WhiteTaco4x4
    Washington
    Without a 3" lift and/or trimming, most people here will tell you the largest tire you can reasonably fit will be a 265/75R16. However, the 275 width tire is lesser known and relatively uncommon. As I mentioned in my previous post, BFG makes the A/T tire with the 275 width, which might fit, but I'm not sure. This is why I wanted to see if anyone else had first-hand knowledge of this size. I can pretty much say for certain that a 285 tire will not fit with just a leveling kit and no trimming.
  10. Aug 3, 2011 at 7:49 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
    nitto trail grappler is the only one ive seen
  11. Aug 3, 2011 at 7:51 PM
    GA_TACO4x4
    here 'n there
    07 DCSB 4x4
  12. Aug 3, 2011 at 7:51 PM
    KPT
    09 Prerunner
    285/60/18s fit with stock suspension and stock wheel backspacing.
  13. Aug 3, 2011 at 7:53 PM
    Yota4wd
    Yota4wd [OP] Member
    Louisiana
    toyo open country at make a 275/70/16. would that fit?
  14. Aug 3, 2011 at 7:54 PM
    KPT
    09 Prerunner
    They are only 31s so you'd probably have a pretty good shot
  15. Aug 3, 2011 at 7:56 PM
    Yota4wd
    Yota4wd [OP] Member
    Louisiana
    but would i still need a lift?
  16. Aug 3, 2011 at 8:02 PM
    Yota4wd
    Yota4wd [OP] Member
    Louisiana
    what about gettin 2inch front leveling kit with 285/75/16 thats about a 32 inch tire
  17. Aug 3, 2011 at 8:02 PM
    09WhiteTaco4x4
    Washington
    I guess I should have stipulated a 285 wide tire on a 16" or 17" wheel.
  18. Aug 3, 2011 at 8:02 PM
    KPT
    09 Prerunner
    :notsure: test fit them and see. Worst case scenario you get a lift, which it sounds like you want anyway. :thumbsup:
  19. Aug 3, 2011 at 8:03 PM
    KPT
    09 Prerunner
    It's all about the sidewall height. The 285/60/18s are only a 32"' thus they are not tall enough to hit the uca.
  20. Aug 3, 2011 at 8:03 PM
    09WhiteTaco4x4
    Washington
    A 285/75R16 is basically the equivalent of a 33" x 11.5" tire.
