Tire sizes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by astott93, Jul 12, 2016.
  1. Jul 12, 2016 at 5:19 PM
    astott93
    astott93 [OP] Well-Known Member
    Austin
    09 Tacoma TRD Sport 4x4
    Bilstein 5100's all the way around.
    I'm currently running a 275/70/17 bfg KO2 and someone is wanting to trade me a 295/55/20. Would I be able to fit that? I have bilstein 5100s on 2nd notch with OME 887 coils.
  2. Jul 12, 2016 at 5:38 PM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    https://www.tacomaworld.com/tirecalc?tires=275-70r17-295-55r20
    According to tire calc they are only .6" over all larger than your current size. That is only .3" on either side of the wheel. I don't see an issue with fitting that. The bigger question is why you would want to swap to a 20" wheel? That limits tire options, limits side wall size (and in turn ability to air down as much), and might make for a rougher ride.
  3. Jul 12, 2016 at 5:40 PM
    astott93
    Austin
    I just like the look of the 20 inch rim. I never take it off road unless I take it to the beach.
  4. Jul 12, 2016 at 5:42 PM
    Pigpen
    Dan
    Northwest Montana
    You preloaded 887s????
    :boom:
  5. Jul 12, 2016 at 5:51 PM
    astott93
    Austin
    Kinda new to this. What do you mean by did I Preload the 887s?
