tire sizes
Discussion in '1st Gen. Tacomas (1995-2004)' started by 406yotalife, Oct 30, 2017.
  1. Oct 30, 2017 at 5:18 PM
    406yotalife
    406yotalife [OP] Member
    Montana
    2002 silver tacoma trd
    3 inch suspension lift 235/85/16 Goodyear duratracs
    does anyone know where to find non metric tires anymore y can't you just buy a set of 34 9s for example
  2. Oct 30, 2017 at 5:20 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    just find the equivalent in a metric and that should suffice. then again they not make the size your looking for anymore either :notsure:
  3. Oct 30, 2017 at 5:27 PM
    406yotalife
    Montana
    I was just throwing out some random size... the hole metric sizes only go so big before u have to buy huge wheels wich cost a lot more then that means the tires are even more... I don't want to put 18s on my truck just to get the size of tire I'd like.. I'd show u a pic but don't know how to put any on here yet
  4. Oct 30, 2017 at 5:32 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You'll find more options for 'BIG" tires on 16" rims than 18". You're overthinking this. Figure out which overall diameter and width you want then figure out which size comes closest. This should help
  5. Oct 30, 2017 at 5:32 PM
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    I'm not sure you have a valid point. Larger tires are usually the ones with the inch measurements.
    I'm sure if you tell us what size you want someone can help.
  6. Oct 30, 2017 at 5:42 PM
    406yotalife
    Montana
    I live in western Montana I want tall and thin for the snow I have 33 12.50 15 toyo m/ts with a 3" lift and they r useless during the winter I'd like to go a little taller and way thinner
  7. Oct 30, 2017 at 5:52 PM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    You could check out 255/85 R16. I think they are around 10.5 wide.
    DustStorm4x4 likes this.
  8. Oct 30, 2017 at 5:53 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    stay the same outside diameter and just get skinnier. https://tires.tirerack.com/tires/33x10.5 15
  9. Oct 30, 2017 at 6:04 PM
    406yotalife
    Montana
    I really like the wrangler duratracs I've got a set of 235/85/16 on my halfton Chevy and I'm hooked now do amazing in snow and don't wear fast on pavement
