Tire Sizes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LTorres_96, Jun 29, 2019.
  1. Jun 29, 2019 at 7:20 AM
    LTorres_96
    LTorres_96 [OP] USAF
    Leroy
    I have a 2009 Taco currently fitted with 245/75r16 size tire and I'm wonder what's the biggest size tire you can fit on stock suspension?
  2. Jun 29, 2019 at 7:52 AM
    20workman13
    20workman13 Well-Known Member
    Loveland, Colorado
    2015 Tacoma DCLB
    I ran 235/85r16 on my stock Tacoma and it was a great combo, drove much better than the factory 265/70r16.
  3. Jun 29, 2019 at 4:25 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    265/70/16 probably tallest and widest.
  4. Jun 29, 2019 at 10:16 PM
    zilla805
    zilla805 Weekend warrior
    San luis obospo
    4x4 TRD
    265 75 16
    You get the height and width. Try anything bigger you probably have rubbing you will probably have to get off set rim
  5. Jun 30, 2019 at 5:35 PM
    glazer1972
    glazer1972 Well-Known Member
    05 Tacoma PreRunner Double Cab 4.0L
    Intermittent Wipers.
    255/80r17 maybe.
  6. Jul 1, 2019 at 6:41 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    265/70/16 is offered as a factory size on some trucks. They are 1" wider than what you have, same height. I'm running 265/75/16's. They are 1" taller and 1" wider than what you have. I've never had an issue. Some guys run 255/85/16's. They are a 33" tire, about 2" taller than stock, but are a skinny tire that will PROBABLY fit on a stock truck.
    There are exceptions. An LT tire, even in the same size is a touch bigger than a P series tire and different manufacturers will be slightly different even with the same size. Brand "A" in a 255/85/16 might fit fine, while brand "B" in the same size may rub just a bit.
    LTorres_96[OP] likes this.
