Tire Sizing Question
Discussion in 'Wheels & Tires' started by badguybuster, Mar 16, 2009.
  1. Mar 16, 2009 at 4:52 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    My truck is running 265/65/R17 currently BUT I found a BAD ASS set of Goodrich A/T tires that are 255/75/R17. How would they affect my truck?????
  2. Mar 16, 2009 at 5:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Current TireNew TireDifferenceDiameter inches (mm)
    30.56 (776.3)32.06 (814.3)1.5 (38) 4.9%
    Width inches (mm)
    10.43 (265)10.04 (255)-0.39 (-10) -3.7%
    Circumference inches (mm)
    96.02 (2438.82)100.72 (2558.2)4.7 (119.38) 4.9%
    Sidewall Height inches (mm)
    6.78 (172.25)7.53 (191.25)0.75 (19) 11.1%
    Revolutions per mile (km)
    659.89 (409.79)629.09 (390.67)-30.8 (-19.12) -4.7%
  3. Mar 17, 2009 at 5:15 PM
    badguybuster
    Michael
    So, ummm, how would that affect my truck??
  4. Mar 17, 2009 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, it might rub, and the OD will be off 4.9%
  5. Mar 17, 2009 at 5:49 PM
    badguybuster
    Michael
    Oh, well, crap. I am having one helluva time finding a L/T tire in my 265/65/17.
  6. Mar 17, 2009 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Try it out. If it rubs, either trim a little but, or get a small lift.
  7. Mar 17, 2009 at 6:01 PM
    badguybuster
    Michael
    I worry about the speedometer difference. I have a lift but it isn't installed yet. Thanks for the help.
  8. Mar 17, 2009 at 6:15 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    LT 255/75/17's will fit stock w/ no issues....i ran them on my 09 for about a week before the lift and had no rubbing at full lock to either side...did make the speedo read correct and it made the ODO read slightly slower...EXTENDED WARRANTY!!
  9. Mar 17, 2009 at 6:18 PM
    badguybuster
    Michael
    Well, it is weird. Everywhere I look, I see tons of the 265/65/R16 but I can not find a GOOD light truck tire in 265/65/R17. I went to Expert tire, Wholesale tire, Appalachian tire, and a couple others. Most tell me that it is near impossible to find above a 4 ply in that size. I tow a lot so I need at least a 6 ply. I mean the 255/75/R17 is only 1/2" difference, right??
  10. Mar 17, 2009 at 6:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    1.5" diff.
  11. Mar 17, 2009 at 6:26 PM
    jhodge83
    SC
    u can get an LT in a 265/70/17 which is a little shorter than the 255/75/17....but the 255/75/17 is a full 32" where the stock 265/65 is a 30.5 i think
  12. Mar 17, 2009 at 7:45 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    When changing tires sizes, can't the ECM or whatever be re-programmed to reflect the new tire size?
  13. Mar 18, 2009 at 9:22 AM
    TacoBow
    TacoBow Intentionally cosmetically incorrect.
    PA
    2012 Tacoma SR5 4x4 Access Cab
