Tire slow leak anything i can do?
Discussion in 'Wheels & Tires' started by kjf216, May 27, 2010.
  1. May 27, 2010 at 8:34 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
    i pulled a screw out of my one tire back around x-mas and plugged it but it just didnt feel like it went in right. I took it to a local tire shop to have it patched and they told me they couldnt patch anything after its been plugged cuz the hole would be too big. they checked the tire everything seemed fine. well the tire picked up a slow leak, at frist it was enough to set off the pressure light every month and half. well between then and now it has slowly gotten worse and it seem like i need to fill the tire up almost every week. my thought was can the old plug be pulled out and the tire repluged. the only other thing that i can think of would be to have my spare tire switch on the bad tires rim but i would really hate to do that since i have about 35,000 miles on my other tires already. any ideas or trick you guys have learned?
  2. May 27, 2010 at 8:36 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    buy new tire -guarantee fix
    DFA
  3. May 27, 2010 at 8:36 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Plugs are great and simple. Get a kit at your local auto store and have at it, it'll work, use glue on the plug. Also, check your valve core and make sure it's tight. Use soapy water to find the leak.
  4. May 27, 2010 at 10:40 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Just use your plug kit 'Ream tool' and push the old plug into the tire, clean the hole again, then put in a new plug. Make sure to use plenty of rubber cement when installing the new one.
    Some plugs do leak a little, but over the course of several months... not weekly, just redo it.
    And "plug hole too large to patch"? Go to a different shop.
  5. May 27, 2010 at 10:43 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Yes , No Bubbles , No Troubles
  6. May 27, 2010 at 10:44 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
