Tire suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Enreeko, Feb 9, 2021.
  1. Feb 9, 2021 at 4:13 PM
    Enreeko
    Enreeko [OP] Member
    Enrico
    Maricopa, AZ
    2020 White Tacoma SR 4x4
    Hey all! New to Tacoma life and looking at some 17/9 wheels and 0 offset. Looking for on/off road tires but am staying stock height.
    Looking for aggressive look and don’t want to run into any issues at stock height. Suggestions on tire size?
    Thanks all!
  2. Feb 9, 2021 at 4:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Toyo Open Country ATIIIs
  3. Feb 9, 2021 at 4:20 PM
    Enreeko
    Enreeko [OP] Member
    Enrico
    Maricopa, AZ
    What size?
  4. Feb 9, 2021 at 4:24 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Whatever size that will not rub with your wheel choice.
  5. Feb 9, 2021 at 4:24 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    265/65R17 if you don't want larger tires than stock
    265/65R17 is the stock size for the 17' wheels
  6. Feb 9, 2021 at 4:27 PM
    Enreeko
    Enreeko [OP] Member
    Enrico
    Maricopa, AZ
    I’m cool with larger tires than stock just staying stock height. I want to go a little wider just don’t want to rub.
  7. Feb 9, 2021 at 4:33 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    265/70r17 is the max for no rub.
    I've seen some people push it for 275/70r17 with some plastic cutting but it heavily depends on your offset.
    285 is cab mount chop territory.
    Almost any A/T tire is fine for daily driving as long as you dont go for Load E. Stay load C or P.
    Enreeko[OP] likes this.
  8. Feb 9, 2021 at 4:41 PM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I am a big fan of Firestone Destination AT2 and Michelin LTX AT2.
  9. Feb 9, 2021 at 4:43 PM
    Enreeko
    Enreeko [OP] Member
    Enrico
    Maricopa, AZ
    thank you - I tow our camper every few months or so for a few hundred miles each way. Need to make sure tires are rated for weight I need
  10. Feb 9, 2021 at 5:19 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    E rated 265/70/17
  11. Feb 9, 2021 at 6:07 PM
    Gswain
    Gswain Eastern sierra living
    I ran cooper st maxx, very happy with them. Ice traction was poor, but very durable on eastern sierra nasty rocks.
  12. Feb 9, 2021 at 6:12 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You will probably need a wheel with a bit of negative offset.
    Stock wheels have a +30 mm offset, which "places" the wheel more into the wheel well.
    The 0 (zero) offset will move the wheel "out" about an 1 1/4 inches, this maybe enough for your 9" rim + tire to clear.
