Tire tread depth different
Discussion in 'Wheels & Tires' started by vettehigh, Jan 10, 2018.
  1. Jan 10, 2018 at 11:58 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Just checked my depth on all 4 of my tires (31/10.5/15) and my fronts are 15/32" and my rears are 13/32". They are General Grabber AT2's. I had it aligned last month and I bought the truck 2+ months ago with the new tires on it. Any issues and/or should I put the deeper tread in the fronts?
    1995 4x4
  2. Jan 10, 2018 at 12:03 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    Big box tire retailer will recommend you to put the tires with the most tread in the rear.
    tcBob likes this.
  3. Jan 10, 2018 at 2:27 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    You're probably fine as long as you're rotating your tires every 5k or so. If the treadwear is even (no unusual wear on the inside/outside of the tread, no cupping, etc.), I wouldn't worry about it.
  4. Jan 10, 2018 at 2:41 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Usually you always want the deepest tread tires on the drive wheels.
  5. Jan 10, 2018 at 3:33 PM
    vettehigh
    Jon
    Upstate, NY
    So I'll just switch the fronts to back correct?
  6. Jan 10, 2018 at 3:36 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Yep, the drive wheels use more tread. So you rotate them to keep the tread depths even from front to rear.
  7. Jan 10, 2018 at 10:14 PM
    Son's rig
    Son's rig Member
    Bret
    2014 Tacoma Access Cab, 4WD, V6, Auto
    3"x 2" lift with 265/75R-16 tires by 1/15/2018
    Ah....have to jump in here folks........on 4WD vehicles, that see 4WD use, run tires with the most tread in the front and at slightly more air pressure than you run in the rear. The reason, there is much more weight in the front with the engine than in the rear and you'll feel much better steering and overall directional traction. On load range C tires, run 32-33 psi front and 28 in the back if you mostly run unloaded. You love the traction and wear mileage! This had been my recipe for decades. Works great!
    photogr4x4 likes this.
  8. Jan 10, 2018 at 10:52 PM
    RedManRocket
    Red
    2002 Double Cab LT
    That is true that the front would weigh more with 4x4 and more psi would be better to compensate this weight, but you would still want the most tread depth on the rear drive wheels. The drive wheels are under much more torsional load than the front making the rear more susceptible to breaking traction, thus wanting more tread in the rear
    03 NIGHT TACO likes this.
