Tire Tread Direction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dustflap, Nov 29, 2015.
  1. Nov 29, 2015 at 10:03 PM
    Dustflap
    Dustflap [OP] Well-Known Member
    I had the dealer do my first free oil change recently on my 2015 2.7 L. base and they put 7 quarts of oil in it. Stick showed 1.5 guarts over full. Had to drain a quart out. I also told them not to rotate the tires, but they did it anyway. I don't know if they did front to back or criss cross rotation ( manual calls for front to back). Anyway, I was looking at the tire tread pattern and the drivers side tires have the outside tread pattern angling toward the rear and on the passenger side it angles towards the front. Does this sound normal for Dunlop AT20's?
  2. Nov 29, 2015 at 10:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You should have taken it back and had them redo the oil change. I have done it before.
  3. Nov 30, 2015 at 6:12 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Directional tires always have an arrow on the sidewall showing rotation direction
    if you do not have directional arrow on the sidewall then it doesn't matter which way the tire is mounted
    YotaDan and DoorDing like this.
  4. Nov 30, 2015 at 8:13 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    AT20's are not a directional tire - no possible way to put them on backwards. Upside-down on the other hand...
    DoorDing likes this.
  5. Nov 30, 2015 at 11:50 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    One thing i did when i bought my truck was mark each rim on the inside with dots to denote tire #. That way i always know how it was rotated.
    RedRed likes this.
  6. Nov 30, 2015 at 4:56 PM
    Dustflap
    I usually mark them and should have, even though they were not supposed to be rotated. I keep forgetting some dealer ship personnel are mentally challenged. I looked at the tread directions on a truck like mine and they were the same. So I guess all is well.
  7. Dec 1, 2015 at 7:37 AM
    tgear.shead
    tgear.shead Well-Known Member
    That is normal for *all* tires.
  8. Dec 1, 2015 at 7:38 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    this is why i dont even bother with the dealership any more. 1.5quarts over... good god.
  9. Dec 1, 2015 at 7:59 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    no
    not all tires
    just most
  10. Dec 1, 2015 at 8:00 AM
    tgear.shead
    Not most, ALL tires.
    Edit;
    The cause is how alignment is set up to counteract the natural drift to the right. Roads slope to the right, so alignment is set up to pull slightly to the left. This kind of alignment causes the banding as described.
  11. Dec 1, 2015 at 1:05 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    :facepalm:
