Tire upgrade in size
Discussion in 'Wheels & Tires' started by campthewestcoast, May 23, 2012.
  1. May 23, 2012 at 10:32 PM
    campthewestcoast
    campthewestcoast [OP] Oceanfisherman
    Napa, CA
    Power extend/retract towing mirrors,brake controller,30amp charging system for TT,snug top camper
    Right now I'm running 245/75/16 on a 06 prerunner. 265/70/16 was an option. I want to run 265/75/16, shouldn't have a problem with rubbing or fit.
    I tow a 4000lb travel trailer, will I have a power loss with the larger diameter tire without doing a gear change?
  2. May 23, 2012 at 10:34 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    you will be fine running the 265/75/16's, and you shouldnt feel any power loss at all.
  3. May 23, 2012 at 10:34 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    No, you don't need to worry about power loss with that size.... Your fine, that size is not dramatically bigger than the 265/70s.
