Tire Upsize Affects TSS?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EmollientFoil, Feb 15, 2022.
  1. Feb 15, 2022 at 5:51 AM
    EmollientFoil
    EmollientFoil [OP] Well-Known Member
    '22 Army Green SR5 Trail Special Edition
    Hello, couldn’t find a specific thread answering this.
    I am looking to go just one size bigger to the 265 75 16, up from my 265 70 16.
    TSS functioning perfectly is important to me, so I’m trying to figure out, essentially that tire will give me 1” extra of height. For those of you who did lifts or tire upsizing, what was the point when TSS stopped working?
    Is it calibrated so sensitively to where I would have an issue, or do you have a few inches of wiggle room before you need to move the sensor down or give up on it working?
    If it helps, I have the new trail edition so I’m factory lifted 1.1/.5 and I have factory heritage grille.
  2. Feb 15, 2022 at 6:11 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    No, you won't have any issues.
    EmollientFoil[OP] likes this.
  3. Feb 15, 2022 at 6:11 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The net change is 1/2 inch lift not 1 inch.
    EmollientFoil[OP] and hiPSI like this.
  4. Feb 15, 2022 at 6:13 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yep.
    shakerhood and EmollientFoil[OP] like this.
  5. Feb 15, 2022 at 6:15 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I have 2.7" suspension lift + 2" from 35" tires + 0.4" from a replacement grille = 5.1" higher. TSS continues to function without any caution lights or warning messages. Adaptive cruise, pre-collision warning, and lane departure alert continue to work. Calibration is probably off from FSM limits though.
  6. Feb 15, 2022 at 6:50 AM
    chazmen
    chazmen Well-Known Member
    JT
    Any issue going from 265/70/16 to 275/70/17 on that new Trail Edition ?
  7. Feb 15, 2022 at 6:53 AM
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    My 2021 Sport has 0 issues with it. Lifted 3.5 with 265/70/17, everything works normal.
  8. Feb 15, 2022 at 7:05 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Between my 1.5" suspension lift and bigger tires that netted another 1.5" ( 3" overall ), I've had no issues.
  9. Feb 15, 2022 at 7:37 AM
    EmollientFoil
    Awesome, this is really good feedback! I figure that we can assume it functions safely and properly until the error code throws.
    Oh yeah I messed up that math thanks for pointing it out. The tire itself is 1” taller in diameter, but that only nets .5” lift?
    hiPSI likes this.
  10. Feb 15, 2022 at 9:38 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yep. a half inch on top and a half inch on bottom. You only get to use the bottom....
  11. Feb 15, 2022 at 9:42 AM
    EmollientFoil
    Yeah, I posted too early today. Lol!
    hiPSI[QUOTED] likes this.
