Tire Vibrations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by petercavazosTRD, May 13, 2019.
  1. May 13, 2019 at 1:05 AM
    petercavazosTRD
    petercavazosTRD [OP] New Member
    Peter
    2019 SR5 V6
    Level/lift- 285 70r17 KO2s
    I have a 2019 4x2 SR5 V6 with approximately 4500 miles. I installed a 3 inch front lift and 1 inch rear block (typical strut spacer kit and lift block) and put the 285/70R17 KO2s on the TRD rims from my 1st gen (5K miles on tires at time) on the truck. Instantly, there was a pretty harsh vibration from about 19-25 MPH when accelerating and decelerating that was not present on the 120k mile first gen. I've determined its not the carrier bearing, pinion angle, everything is torqued properly and my local alignment shop told me that the vibration is coming from the tires. It did not really get better with a balance and alignment, but I'd love to know if anyone has the same issue and/or has fixed it. I've tried rotating the tires and I run them at 32-34 psi. I have friends with KO2s on their third gens with the same rims and leveling kits but they do not have this vibration. Help Please <3! :(
  2. May 13, 2019 at 1:59 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    KO2s can be a bitch to balance depending on the batch yours came from. Possible ECGS bearing too. Try rotating tires and seeing if that changes anything. If you say all tires are good but the tire shop is saying it’s the tires... move the problem tire and see if the vibration moves.
  3. May 13, 2019 at 10:44 PM
    petercavazosTRD
    Peter
    2019 SR5 V6
    Thanks man I'll give it a go. Still open to suggestions everyone! If anyone can help me, it's the tacoma world community
    jmauvais likes this.
  4. May 13, 2019 at 11:59 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    19 to 25mph vibrations are not tires. Tires are usually 55 to 65mph It's your driveshaft angle . 3 degree shims should help. Does it disappear when 4wd is engaged ? If yes it's time for ecgs bushings
  5. May 14, 2019 at 12:00 AM
    petercavazosTRD
    Peter
    2019 SR5 V6
    I tried some carrier bearing spacers but no cigar. My local shop whom I trust very much said tires as well as the alignment shop
  6. May 14, 2019 at 1:14 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    The OP truck is 2wd.
    petercavazosTRD[OP] likes this.
  7. May 14, 2019 at 1:27 AM
    petercavazosTRD
    Peter
    2019 SR5 V6
    the truck also only has 4500 miles
  8. May 14, 2019 at 1:59 AM
    Wickedale
    Wickedale Member
    La Grange Texas
    2019 QuickSand Tacoma TRD Off-road
    I had the same issue with stock TRD wheels on my 2018 4Runner. Nitto Terra Grapplers 275/70/17 shop aligned three times, vibrations still present. The fix was
    balancing the wheel and then mounting the tire to it. (Indexing tire to wheel). All good now.
