Tire Wear and Humming Noise
Discussion in 'Wheels & Tires' started by maverick01, Oct 5, 2015.
  1. Oct 5, 2015 at 8:10 PM
    maverick01
    maverick01 [OP] Stormtrooper
    Connor
    Oregon
    13 TRD Off Road
    3" Rough Country Lift, 17" Fuel Revolver Wheels, Mickey Thompson Baja MTZ 285/70R17, Blacked out emblems, 30" Bumper Mounted LED Light Bar, Leer Canopy, LED Interior Lighting, TRD Grill Badge, OEM roof rails
    So back in March I finally installed a 3" lift and 33" mud tires on my '13 TRD Off Road. I went with Mickey Thompson Baja MTZ's and I haven't had great luck with them. At the moment I'm having a weird humming sound around 35-40 mph sounds/feels like "wobwob, wobwob, wobwob..." Also the front left was wearing noticeably more on the outer edge. I took it to Tire Factory and had them rebalance and rotate them. They said they weren't much out of balance... What could this be a sign of? Is this pretty normal?
  2. Oct 5, 2015 at 8:12 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    Alignment, tire pressure, maybe rotate more frequently, road force balance?
  3. Oct 5, 2015 at 8:23 PM
    mbroughton02
    mbroughton02 Well-Known Member
    Michael
    Cortland, NY
    07 DCLB
    OME 884, 5100s, Wheeler's 1.5" Progressive AAL, Firestone Ride Rite, Fisher Homesteader 7'4" Plow, Heated Seats, Viper 5806v Remote Start / Alarm.
    Did you have an alignment done after the lift? What were the results, particularly the toe readings?
    For the noise you most likely need to replace the front differential bearing on the driver side with a bushing from East Coast Gear Supply. There is a whole thread dedicated to this: https://www.tacomaworld.com/threads...differential-bearing-vibration-thread.152173/. The stock bearing can't handle the new angles from your lift. I am doing this myself next weekend.
  4. Oct 5, 2015 at 8:34 PM
    maverick01
    Connor
    Oregon
    13 TRD Off Road
    Had an alignment after the lift, don't know the readings...Front diff replacement sounds like what I need done. Thanks for the help!!
  5. Oct 6, 2015 at 1:55 PM
    roguetrader
    roguetrader Well-Known Member
    I have the exact same issue. Just started after a 800 mile road trip.
