Tire Wear
Discussion in 'Wheels & Tires' started by blacktoy, Nov 19, 2011.
  1. Nov 19, 2011 at 3:10 AM
    blacktoy
    blacktoy [OP] Active Member
    NB, Canada
    Tacoma TRD
    Side Steps Tonneau Cover
    Hi, I am new to the truck and Tacoma World. This may seem like a basic question but here goes...
    1. Do tires wear faster on the front or the back (tacoma trd 4x4 double cab)? (reason I ask is that I got used winter tires with the truck and two are more used...want to try to get evened out...)
    2. I have just put a lift kit...1.5'' blocks in the back and 2'' billet in the front...do tires use funny with a lift kit...anything to check or be careful?
    Thanks for your help!!
  2. Nov 19, 2011 at 3:14 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    answers are above in bold! good luck
  3. Nov 19, 2011 at 3:21 AM
    blacktoy
    NB, Canada
    Tacoma TRD
    Thanks for the reply!!
    As for the question of tires wearing funny...I did get an alignment...just wondering if I should rotate more often or something else to watch out in order to max out tire life...thanks
  4. Nov 19, 2011 at 3:29 AM
    97yota4wd
    Eric
    Mesa, AZ
    rotating tires is always a good idea. do it the same amount as when your truck isnt lifted!
  5. Nov 19, 2011 at 3:35 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Yea I rotate my tires every oil change
  6. Nov 19, 2011 at 3:36 AM
    blacktoy
    NB, Canada
    Tacoma TRD
    Thanks all!! I will follow that advice...
