Tire wear
Discussion in 'Wheels & Tires' started by GRS, Sep 24, 2017.
  1. Sep 24, 2017 at 9:44 PM
    GRS
    GRS [OP] Member
    2017 Tacoma 4 door TRD offroad
    Hello everyone, new here. I have a 2017 4 door TRD off road with Goodyear wrangler Kevlar tires. I just turned 23K mileage and noticed both front inside tires are wearing exceptionally fast, from the first tread groove inward. Anybody out there having this problem or heard of this issue....Thanks. Gary
  2. Sep 24, 2017 at 9:46 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    what PSI are you running?
  3. Sep 24, 2017 at 9:47 PM
    GRS
    GRS [OP] Member
    32-35 psi cold... I previously owned a 2004 TRD Taco with same prob, Toyota replaced the ball joints, said there was a service bulletin on them. Cost me nothing.
    But hard to believe worn out with less than 40K
  4. Sep 24, 2017 at 9:57 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Do you rotate your tires every 5k miles like your required maintenance tells you to?
  5. Sep 24, 2017 at 10:03 PM
    GRS
    GRS [OP] Member
    No. Regardless of tire position, they will wear the same in the front position. Over all the vehicles I have had I usually rotate at about 30k, half life of tire and have had excellent wear. 5K is bullshit in my opinion. I believe this is either an adjustment problem or a worn out part problem.
  6. Sep 24, 2017 at 10:15 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No no no. You have 23K on this vehicle. That means your data on rotation had to come from previous vehicles. Except, every vehicle is different, so history can only be used as a guide, not definitive rule.
    With that said, on some vehicles the fronts wear different than the rears. If the rears wear even and the fronts wear the outside edge, when you rotate front to rear you get more tire life. Logic.
    I've had some vehicles I NEVER had to rotate. I've had some I had to rotate every 5K. So far on this truck, after studying the difference between front and rear tire wear, 10K looks like a good figure for my vehicle and driving habit. Most mileage for me is interstate.
    It could be alignment but I doubt it. Rotate the tires every 10K oil change. You will have a much longer lasting set of tires.
    Roland79 likes this.
  7. Sep 24, 2017 at 10:17 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    When was the last time you had an alignment?
  8. Sep 24, 2017 at 10:22 PM
    GRS
    GRS [OP] Member
    No alignment yet. No big hits, should not need yet.
  9. Sep 24, 2017 at 10:24 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Your PSI is a bit high for stock tires, you aren't rotating your tires, and you dont think you need an alignment....
    Good luck OP, sounds like you have the answer already.
    SilverYeti, JET4, irayfz6 and 2 others like this.
  10. Sep 24, 2017 at 10:30 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Uneven tire wear means bad alignment but you feel like you don’t need one.
    You don’t rotate your tires.
    This is a bad mix.
    irayfz6 likes this.
  11. Sep 24, 2017 at 10:30 PM
    GRS
    GRS [OP] Member
    Well like I said I previously owned a 2004 TRD off road which developed the same prob at around the same mileage. The fix for this was the ball joints which had a recall/ service bulletin out on them. My 2007 Taco TRD had zero probs with tire wear. Taking truck to dealer tomorrow since still under warranty. I will update page when I can...thanks....Hopefully alignment is all it needs.
  12. Sep 24, 2017 at 10:32 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    There’s no recalls for ball joints on the 3rd gen.
    Your 2007 had an alignment in spec.
    Go to the dealer and pay the $80-100 to get it aligned.
  13. Sep 25, 2017 at 3:53 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You'd be surprised...
    I'd guess your toe is zero to toe-out.
    Myself and others were told 2 free alignments by the dealer. I had one done at less than 5,000...
  14. Sep 25, 2017 at 5:43 AM
    GRS
    GRS [OP] Member
    Thanks, taking in today for alignment check. :thumbsup:
  15. Sep 13, 2018 at 7:01 AM
    Fenahs
    Fenahs New Member
    2017 Tacoma Off-Road
    I have the exact same problem. Practically the exact same truck. Any resolution from your dealer?
  16. Mar 5, 2019 at 5:08 PM
    ehvyy
    ehvyy Well-Known Member
    Evan
    2018 Toyota Tacoma TRD Off Road
