Tire wear
Discussion in 'Suspension' started by tomcat67, Jan 26, 2023.
  1. Jan 26, 2023 at 7:30 AM
    tomcat67
    tomcat67 [OP] Member
    2004 Toyota Tacoma 4x4
    2” lift
    My 2004 Tacoma 4x4 is wearing the inside of my tires my alignment bolts are maxed out is there a aftermarket replacement bolt to fix it?
  2. Jan 26, 2023 at 7:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lift type? Wheel type?
    Assuming the UCAs stock?
    Post alignment numbers?
  3. Jan 26, 2023 at 7:35 AM
    tomcat67
    2” lift
    2” lift 265/75-16 tires not sure on the rest
  4. Jan 26, 2023 at 7:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    What kind of 2" lift? And you don't know if your UCAs are stock?
  5. Jan 26, 2023 at 8:03 AM
    tomcat67
    2” lift
    Suspension lift and the drivers side looks like it’s stock
  6. Jan 26, 2023 at 8:11 AM
    tomcat67
    2” lift
    Here’s the alignment numbers left camber -1.2 degrees right camber 0.3 degrees
  7. Jan 27, 2023 at 6:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    No toe or castor numbers?
    What did the alignment shop say? The left camber number is whacked. is that the tire with wear?
    Assuming you have a good tech doing the work and nothing is broken or bent, a 2" lift generally doesn't need aftermarket UCAs. And a good tech will tell you what is needed to correct the alignment.
