Tire wear
Discussion in 'Suspension' started by tomcat67, Jan 26, 2023.
  1. Jan 26, 2023 at 8:36 AM
    tomcat67
    tomcat67 [OP] Member
    2004 Toyota Tacoma 4x4
    2” lift
    I have a 2004 Tacoma double cab 4x4 tires are wearing on the inside and alignment bolts are maxed out
  2. Jan 30, 2023 at 8:25 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. Inside edge tire wear typically means too much negative camber. If you have your LCA alignment bolts (eccentrics) already maxxed out then something else might be going on. Have you checked condition of your ball joints and UCA/LCA bushings?
  3. Jan 31, 2023 at 2:06 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Could be the toe setting too (toed-out if the wear is on the inside of both tires).
