Tire wear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Austin1197, Feb 7, 2024.
  1. Feb 7, 2024 at 8:07 PM
    Austin1197
    Austin1197 [OP] New Member
    Austin
    2019 2wd sr Tacoma leveled on 33s
    I have 2019 Tacoma 2.7 2wd leveled on 33s with 20 inch rims. I have recently gotten noisy tires and can hear the tread. After looking at them it’s clear the outsides are wearing noticeably faster than the inside. It’s happening on the front and rear wheels. I have ridge grapplers my first set was amazing and lasted 80,000 miles this set is 30,000 in and I’ve done alignments and rotations. Is it possible it just needs another alignment? Also can you achieve a 4 wheel alignment on a 2wd truck?
  2. Feb 7, 2024 at 8:48 PM
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    If both the outside and inside are wearing faster then the center, then your tires are underinflated and need air.
    If it's just the outside or just the inside, then it's probably the alignment.
    Chew and Trdsandycheeks like this.
  3. Feb 7, 2024 at 8:52 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    What PSI are you running? As stated above, the wear could be indication of under inflation. When you say outsides, do you mean the outer and inner edge? And by inside do you mean middle? Or do you literally mean the outside edge is wearing faster than the inner edge?
  4. Feb 7, 2024 at 8:57 PM
    Trdsandycheeks
    Trdsandycheeks New Member
    Colin
    23 OR MT
    Another thought could be looking into new upper control arms if you are still using the factory ones.
  5. Feb 7, 2024 at 9:02 PM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    Chalk test. YouTube it.
  6. Feb 8, 2024 at 12:12 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Sounds like your camber is incorrectly set. Back to the alignment shop.
  7. Feb 8, 2024 at 12:21 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What does “outsides” mean?
    Both edges of the tire at the sidewall?
    Or just one edge, on the “outside” edge of the tire?
    Chew likes this.
  8. Feb 8, 2024 at 3:35 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Outter edge of the tread.
  9. Feb 8, 2024 at 3:37 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Tire pressure
    Alignment
    Rotation
    All are critical for tire life.
  10. Feb 8, 2024 at 3:50 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    The rear alignment is fixed on both 2 and 4wd so more than likely you’re seeing wear on the rear tires because they used to be front tires. (Rotations)
    Toe is the typical culprit in tire wear. Camber can affect it but at a much slower rate than toe, unless it’s grossly out of spec which you would be able to visually see.
    Austin1197[OP] and Chew like this.
  11. Feb 12, 2024 at 9:19 PM
    Austin1197
    Austin
    I’ve had it aligned tires rotated and balanced I don’t have any sort of unusual wear but I still hear so much tire tread noise when I never did before. I can be driving straight and turning left and it makes the noise but when I turn right it’s quite and back to normal all of this is at minimum 35mph
  12. Feb 12, 2024 at 9:21 PM
    Austin1197
    Austin
    I was told maybe it’s a rear axle bearing
  13. Feb 13, 2024 at 3:01 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Size tires and width wheels are you running?
    Are you SURE it’s tire noise and not a wheel bearing or axle bearing?
    Certain could be a bearing
    Austin1197[OP] likes this.
