Tire weight differences?
Discussion in 'Wheels & Tires' started by Jason in KC, Apr 29, 2022.
  1. Apr 29, 2022 at 9:20 AM
    Jason in KC
    Jason in KC [OP] Well-Known Member
    For those of you with M/Ts and/or E-load tires, how much has that effected your power, MPGs, and ride on a V6? I'd like to run a 275/70/17 MT, but they're literally ~20 lbs. heavier than the stock minivan tires on my Sport.
  2. Apr 29, 2022 at 9:40 AM
    Jrunr619
    Jrunr619 Well-Known Member
    I am curious about this too. How much of a weight difference would there need to be to actually get a performance change?
  3. May 12, 2022 at 12:17 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I've never calculated the difference in MPGs as you would have to use and test both type of tires for a period of time to get an accurate comparison. However, I do know that I can feel an acceleration and braking difference with tires only having a 3-4 lbs difference.
    Jason in KC[OP] likes this.
  4. May 12, 2022 at 1:26 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you are worried about a 1-3mpg loss, stay with the mini van tire.
    Buttskevin21 likes this.
  5. May 12, 2022 at 1:31 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Varies, with my 69lb 35s, 35lb wheels and stock gears I can either get 10mpg floored everywhere, or 18-19 cruising the speed limit on the highway. Its obviously slower, but still can pass people just fine, still goes 100+, and after driving a stock truck the other day it isnt an insane difference. When my truck was more stock/less armor, I pulled 20mpg with 35s and stock gears from Washington to Utah.
  6. May 12, 2022 at 1:39 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    I am running 215/85/r16 e rated Firetstone Destination XT's because the 245/75/R16's BFG KO's on steel wheels my truck came with reduced my mileage 10-14%, they were noisy, acceleration was horrible, and I felt it was hard on components. There was an18lb weight difference per wheel between those and my new Firestones on alloy rims. People say that a pound of unsprung weight equals about 2-5 pounds of sprung weight, so at 18lbs heavier, that's at best 144lbs, at worst 360 lbs. I'm going to say it felt like the latter.
    Best scenario? Run 2 sets of rims.
    I have some P rated 245/75Rr16 "minivan tires" on rims, and the Firestones on another set for road trips that will see offroad segments, and winter, as the Firestones are snowflake rated and very good in the snow (obviously not as good as X-ice, etc.)
    2 sets of tires last twice as long as 1 set, and therefore, the only additional cost is the second set of rims. I picked some up for $100.
    It's nice having quiet tires, and tires that I know will work well in winter.
    Note that I have the 4 cylinder, but regardless of vehicle, heavy wheels/tires are not great unless you need the extra protection or are concerned with looking all macho.
  7. May 13, 2022 at 4:05 AM
    Pete_Patter
    Pete_Patter Well-Known Member
    2018 Calvary Blue Tacoma TRD Pro
    Lost around 4 mpg when I went from stock 265/70R17 to Mickey Thompson ATZP3 LT265/75R16 then lost another 1-2 mpg when I went to Cooper Discoverer ATPII's in LT285/75R16. The Mickeys are a hybrid tire with 3 ply and the ATPII's are a AT tire with 2 ply. the weight between the Mickey and Cooper are almost the same weight just different overall dimensions.
  8. May 13, 2022 at 4:28 AM
    Jason in KC
    No shit, but I'm not worried about 1-2 MPG. More about power loss than anything. Going from a 35 lb. tire to a 58 lb. tire is quite a jump.
    But I went ahead and pulled the trigger on 275/70/17 Yokohama MTs on SCS Gen5s - going on next week.
  9. May 13, 2022 at 9:29 AM
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    At close to $8.50 a gallon, I would prefer to not lose many mpg. That and it also decreases range per tank.
