Tire weight dilemma
Discussion in 'Wheels & Tires' started by NiceTaco, Jan 14, 2013.
  1. Jan 14, 2013 at 5:16 PM
    NiceTaco
    NiceTaco [OP] Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    I am planning on 265 65 18 tires for my taco.
    I like the BFG AT's a lot they are pricy but I don't mind as they are Proven tire. The problem I am thinking is they are a heavy tire so I am concerned about my mpg. I have also been looking at the new Toyo open country AT 2's they seem to have a nice aggressive Appearance and a very good tread life and I can get the P rated tire as that will do fine for my use so the weight is about 10 lbs less. Tire... That seem like a lot but again I am no expert so here I ask......
    Will there be a huge difference in mpg between the two? I drive a ton of highway.
  2. Jan 14, 2013 at 9:52 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Any kind of weight saving you can get always helps. As to how much of a difference you'll see is hard to determine. We can only speculate and even then it's just a wild guess. If you're upgrading your stock wheels, take that into consideration as well. Try to balance out the combo as best as possible. More often than not, P rated tires will provide a smoother, quieter, and better handling ride for daily use.
  3. Jan 14, 2013 at 9:54 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    If you're not hauling or driving off road I'd stick with P rated and I'd probably choose the AT3 over the BFG. 10 lbs per tire is a decent amount.
  4. Jan 14, 2013 at 9:59 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    I have P rated and did not lose any mpg when upsizing to 265/75R16. Most people who get LTs in the same size seem to lose 1-2 mpg, which may not sound like a lot but is around a 10% decrease.
