Tire weight. What am i looking for?
Discussion in 'Wheels & Tires' started by MapleMoose, Mar 18, 2011.
  1. Mar 18, 2011 at 9:47 AM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I am currently looking at some tire options for the Toyo Open Country M/T's.
    Im want the 285's but im not sure how wide i should go. I know the weight of the tire is going to be a factor. So my choices are: 11.6" wide for 68.3 lbs or 11.1 for 60.6 lbs. I know those 8 lbs on each tire is going to make a difference. Any thoughts?
  2. Mar 18, 2011 at 9:50 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I heard that for every 10 extra pounds in tire weight, it is equivalent to having an extra 200 lbs in the truck.
  3. Mar 18, 2011 at 9:52 AM
    fishnhunt
    fishnhunt Member
    Ontario
    05 Taco sport
    3' suspension lift DVD player Toyo mud tires
    I run Toyo open country Mud Terrains, they weigh about twice as much as a stock tire...but they sure do work magic in the mud...good luck I would stay go with the 11.1
    cheers
  4. Mar 18, 2011 at 11:08 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Say goodbye to your Gas. With all the uprising in the Middle East, the gas prices are only going to get higher. You'll be paying for it everytime you filll up the tank. Just a thought.
