tire weight
Discussion in 'Wheels & Tires' started by rick, Sep 20, 2007.
  1. Sep 20, 2007 at 4:55 AM
    rick
    rick [OP] `
    i know the brakes pretty much suck on 2nd gen. tacomas. but are there any other disadvantages of running a heavy tire (61 lbs). im looking to run an m/t. the bfg m/t's weigh 50 lbs vs the firestone m/t's weighing 61 lbs. thanx for all your expert advice
  2. Sep 20, 2007 at 8:26 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Just for the record, i dont have a problem with the brakes on the Taco. I've stopped faster in cars but for a truck this size i'm pretty happy with them. Although i probabaly will put performance pads and disks on when its time to change them out. you can never stop too fast (unless you hit a wall....)
  3. Sep 21, 2007 at 2:34 PM
    Map06TRD
    Map06TRD Well-Known Member
    firestone weight 61lbs wow... iam getting some remington mud brutes 51lbs..
    also weight is different from load range D and E.. E's will be heaveyer...
    stick with D's for our trucks..
  4. Jan 14, 2011 at 6:07 PM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    i have seach high and low all over the internet for the wieght of specific tires where the hell do you guys find the weight of tires?
  5. Jan 14, 2011 at 6:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Many manufactures list the weights on their sites.
  6. Jan 14, 2011 at 6:11 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    I have 285 BFG KM2 and i upgraded to SS brake lines and ceramic pads and i can stop my truck quick!
  7. Jan 17, 2011 at 7:22 PM
    Joepbj
    Joepbj Member
    Joe
    Richmond, VA
    2011 TRD Sport
    Go to Tirerack.com and then when you select what tire you want to check out, click on "Specs" and they list every possible weight and dimension for every size that particular tire comes in.
  8. Jan 17, 2011 at 7:24 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    the worst thing about a heavy tire is mpg and accelerating
