Tire & wheel advice for 3" Toytec Ultimate lift..
Discussion in 'Wheels & Tires' started by koakai29, Mar 8, 2011.
  1. Mar 8, 2011 at 8:42 PM
    koakai29
    koakai29 [OP] Member
    Brandon
    Jackson, Wy.
    2010 TRD LongBed Sport
    Hello again gents,
    Thanks in advance for any/all (helpful) guidance and advice. I have a 2010 double cab TRD sport, and use it to commute 400+ miles a week. I'm also a recently disabled vet, so ride while commuting is important. I want to add bushwacker flares, lift 3" and add wheels/tires. So, I'm leaning towards the Toytec Ultimate lift and the UCA's. I currently have OEM alloy 17x7.5, 5.5 bs, 42mm offset, on 265's, of course no rubbing offroad (hunting/camping).
    I'm looking at 17x8, zero offset, 4.5 bs, and want to know how big of tires I can mount w/o cutting, etc., to avoid rubbing and still have them look good, i.e., equal with or wider than flares (which looks good, IMHO)..
    Thanks again...
  2. Mar 9, 2011 at 4:25 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If you aren't willing to cut, then even with the lift and the 4.5" backspacing, you still can only fit 265/70/17.
    If you trim some of the fender well plastic, and possibly chop the cab mount, you can fit 285/70/16.
