Tire/Wheel balancing issues
Discussion in 'Wheels & Tires' started by bkc2115, Oct 11, 2011.
  1. Oct 11, 2011 at 8:03 AM
    bkc2115
    bkc2115 [OP] Member
    BC
    Tennessee
    Tacoma SR5 4x4
    2" lift with 285/70/17 Nittos on XD diesel wheels
    Hey guys! I need help before I pull the trigger on my Taco and go to another brand of trucks! I have 2010 Tacoma that I lifted 2" and put a set of 285/70/17 Terra Grappler Nittos on XD Diesel wheels. I have had this truck at different tire shops and have tried everything, including road force balancing, to get them balanced out without any luck. I had a 06'Tacoma that I tried to put after market wheels and tires on and the same issue and ended up going back to stock wheels and tires. Bought this latest truck new and BOOM, same friggin' issue. Need help guys or I am rollin' on up to a GMC/Frord dealer soon! I'm about done with this crap!!!!!!!:mad:
  2. Oct 11, 2011 at 9:16 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
  3. Oct 11, 2011 at 9:34 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Oct 11, 2011 at 9:38 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    not sure how the truck would be to blame for the wheels not balancing...
    maybe the wheels are irregulars?
    maybe the 2" lift was installed wrong?
    maybe the lift is a cheap top mount spacer?
    when they put the wheels and tires on the balance machine, does it show that they are balanced, but when you drive on them, they don't feel balanced?
    if so, maybe double check the suspension... i recall someone having what seemed like a balance issue but after tearing the front end apart, discovered it was a blown front shock that was making his front passenger wheel bounce around like a big booty stripper...
    :D:D:D
  5. Oct 11, 2011 at 9:48 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    Exactly the questions I had!
    Do you need a diff drop?
    carrier bearing spacer?
    Blaming toyota for aftermarket mods done to a truck might be the wrong way to look at the situation.
    Let us know what suspension you have.
    Thats a big tire for a 2'' lift, be careful with rubbing.
  6. Oct 11, 2011 at 9:50 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    oh that's right... carrier bearing...
    if that is off because of the lift, it will vibrate enough to make you think your truck is falling apart...
  7. Oct 12, 2011 at 11:53 AM
    bkc2115
    bkc2115 [OP] Member
    BC
    Tennessee
    Tacoma SR5 4x4
    2' Toytec in front, 1" in the back. Installed at the dealership by a master mechanic who owns 77 Toyota trucks! (He owns a huge rock crawling/mud park and builds Toyota trucks for that purpose in his off time. Got a topper on the back, needed the 1" on the back to level it back out. Not a carrier bearing issue. Already had that checked. But they did find a bad u joint. When I bought the truck new off the lot, I had the mod's done at the dealer. They TOLD me my warranty would not be effected....BIG LIE! Took the truck in for the vibrating issue, Toyota now says that the mods were done at the dealer, my warranty is void, at 29,000 miles. So thats another reason to go Ford/GMC. But, I am faithful! Love my Toyota, but it ain't lovin' me back. Going to try the airsoft to see what happens.
  8. Oct 12, 2011 at 1:34 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    are the wheels hub-centric? if not, did you/they use hub-centric rings?
