Tire & Wheel Fitment
Discussion in 'Wheels & Tires' started by dubstar2003, Apr 3, 2010.
  1. Apr 3, 2010 at 9:06 PM
    dubstar2003
    dubstar2003 [OP] Active Member
    Jacob
    Texas
    2007 PreRunner
    Projector Headlights Westin Bullguard Westin Nurf Bars Custom Hood Lifts Black'd Out Badges Alpine Headunit w/Ipod Satoshi Grille 6000K HID'S BILSTIEN 5100'S UP FRONT
    I am getting a set of stock 20" rims off a Tundra and putting them on my '07 Tacoma TRD Sport. Ive read some of the other post about largest tire with stock suspension, but from what I read it depends on the wheels size. The 20's are wrapped with 285/50/20 tires. Will these fit on my stock TRD Sport suspension. If so, anybody know of any modification needed (ie spacers)?
  2. Apr 3, 2010 at 9:10 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Are you sure the lug pattern matches. IIRC the tundra is different.
  3. Apr 3, 2010 at 9:12 PM
    topgun155
    Zack
    Also if they work, they will fit on stock suspension.
  4. Apr 3, 2010 at 9:29 PM
    dubstar2003
    Jacob
    Texas
    2007 PreRunner
    I think they are the same. The rims are from an 2004 Tundra, but they put the same rims on the '05 & '06 TSS Tacomas, so Im thinking the bolt pattern are the same.
  5. Apr 3, 2010 at 9:31 PM
    topgun155
    Zack
    Worth Checking.
  6. Apr 3, 2010 at 9:34 PM
    dubstar2003
    Jacob
    Texas
    2007 PreRunner
  7. Apr 3, 2010 at 9:37 PM
    dubstar2003
    Jacob
    Texas
    2007 PreRunner
    thanks. the bolt patterns are the same. mostly concerned about tire size.
  8. Apr 3, 2010 at 9:55 PM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    08 Prerunner Texas Edition
    Check out my pics, I think I have the same wheels, they came stock on the Texas ed.
  9. Apr 4, 2010 at 3:44 PM
    topgun155
    Zack
    Looks Good Dub
  10. Apr 4, 2010 at 6:01 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    bolt pattern is the same and 285/50/20's will fit on stock suspension as long as the offset is correct. if you can find out the wheel width and offset i'll be able to tell you for sure if they will work.
  11. Apr 4, 2010 at 7:36 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    285's will not fit on stock suspension without major trimming. Period. Most people even have to trim for 285's with a 3 inch lift.
  12. Apr 4, 2010 at 7:59 PM
    TacoSupreem
    Hayden
    Kentucky
    ^^^285/50/20's are 31" tall and they WILL fit on stock suspension with the correct offset wheel! PERIOD!
  13. Apr 5, 2010 at 7:21 AM
    KPT
    09 Prerunner
    Aren't they going to rub on the fender or body mount due to their width? I know the height is fine.
    Even if you push them out pretty far, I would expect them to rub on something when turning.
  14. Apr 5, 2010 at 7:48 AM
    TacoSupreem
    Hayden
    Kentucky
    Mine didn't. It's close but it will work:)
  15. Apr 11, 2010 at 4:54 PM
    dubstar2003
    Jacob
    Texas
    2007 PreRunner
    Thanks everyone... Hey tacosupreeem. What is your suspension setup front and back? I was actually looking at getting the same rims you have. What offset are they? Do you have any spacers? Where the TC UCA necessary. I really don't want to lift my truck. I heard it throws off alignment then you have to get UCA then diff drop and some people still have vibrations and alignment problems.
  16. Apr 11, 2010 at 6:31 PM
    TacoSupreem
    Hayden
    Kentucky
    dubstar2003, Now i have the ome lift with the TC arms. I have the kmc hoss in black that are 20x9 with a +18mm offset and 5.71" backspace. I dont have any spacers and they fit just fine. The only rubbing issue i've had is a slight scrubbing on the lca at FULL lock.(basically when the wheels are cranked all the way in one direction.) This is caused by the 11.5" wide tire. Its not bad though! You can run these wheels and the 285/50/20's on stock suspension, however i cant say whether or not you will rub the front mudflaps because i took mine off and sold them before i put the wheels on. The lift did throw off my alignment, before the tc uca's the best alignment spec. i was able to achieve was 0-toe,0-camber, and +1 caster. It drove decent but did tend to wander at interstate speeds.(70mph) So i drove it like that for awhile till i had the money to get the TC uca's. I never did install the diff. drop. I personally didn't have any vibrations and didnt see the need for it. Hope this helps?
