Tire/wheel question
Discussion in 'Wheels & Tires' started by FEARFACT, May 15, 2016.
  1. May 15, 2016 at 12:09 PM
    FEARFACT
    FEARFACT [OP] Well-Known Member
    03 double cab 4x4
    coilovers,33s etc
    Tossing 5100s on my parents 3rd vehicle for them (08access cab 4x4,6spd 4.0), probably set on the middle- I believe about a 1 in lift, may go higher depending how it sits and likely a set of 265/75r16 and black steelies.. Seem like a reasonable little setup to you all? This wont get alot of miles and used mainly for fishing and random running around as they have ample and both hate this truck anyway...my question is backspacing as I found the steelies cheap through jegs but want to get it right...any other input as to if bigger tires will fit or if we could go with 15s instead would be great!
