Tire/ wheel size (20?)
Discussion in 'Wheels & Tires' started by Rollin77, Mar 8, 2013.
  1. Mar 8, 2013 at 9:21 AM
    Rollin77
    Rollin77 [OP] Member
    Sudbury, Ontario, Canada
    '11 Blown Toy Taco TRD Sport
    TRD supercharger. TRD catback.
    Hi guys, simple question. I'm wondering if I can run 20" wheels (+15 offset) with 285/50/20 tires with the stock TRD sport, or will any of the leveling kits work? I've been reading about trimming etc, any major issues? (It's hard to search when I'm at work on a phone). I Wont be doing much offroading. If theres no way this will work, what is the best wheel size? Thanks for the help.
  2. Mar 8, 2013 at 6:01 PM
    Rollin77
    So I used the tire calculator, moving from 265/70/R17 to 285/50/R20 actually creates a smaller overall diameter. The only size that grows is the width by just over half inch. I don't see a problem just from the numbers. If the width is an issue could the offset help (+15) or even a wheel spacer? Anyone try this? Thanks for your help
  3. Mar 9, 2013 at 8:48 PM
    Rollin77
    Wow awesome response thanks
  4. Mar 9, 2013 at 9:07 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    You could run 1" wheel spacers if you have rubbing issues. You'll rub on the upper A Arm most likely
  5. Mar 9, 2013 at 9:31 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Problem with a 20' wheel assuming you can get the proper offset or get there with spacers is that to keep the overall diameter to 32" max you are going to end up with the short sidewall like the 285/50R20 you mentioned. This will be acceptable for a Sport Truck tire that is intended for street use but very limiting for off-road use for several reasons. If you like the look of the larger wheels and don't mind the reduction in off-road capability then go for it!
  6. Mar 10, 2013 at 9:10 AM
    Rollin77
    Well other than hitting a dirt road from time to time, I don't do much offloading. And if I knew I had to get dirty I could always throw on the stock combination. I'm waiting on a response from the wheel manufacture but if its a go these wheels will look great. Would a levelling kit help? I feel I need one anyway!!!
  7. Mar 10, 2013 at 9:18 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Depending on the leveling kit, you still get full uptravel from the suspension, so permissable max tire size remains the same as stock.
