Tire width question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mcdowell, Jul 30, 2011.
  1. Jul 30, 2011 at 5:25 AM
    mcdowell
    mcdowell [OP] My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    2011 prerunner with P245 /75 R16 width. What is the max width i can put on without scrub??[​IMG]
  2. Jul 30, 2011 at 5:36 AM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
  3. Jul 30, 2011 at 5:38 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Well I took the same route as you and decided not to use the search button. That being said I heard you can fit 355's in there with room to spare. On stock rims no less.
  4. Jul 30, 2011 at 5:40 AM
    mcdowell
    mike
    mobile al
    2011 prerunner SR5
    Thanks
  5. Jul 30, 2011 at 5:43 AM
    04taco2wd
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    Haha. I was going to say something like this but I decided to be nice...
  6. Jul 30, 2011 at 8:19 AM
    mcdowell
    mike
    mobile al
    2011 prerunner SR5
    I tried search first. Saw only highth not width. I mean really what the eff does it matter. Ha........forum police ?? really?
  7. Jul 30, 2011 at 8:26 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245HP
    3" OME lift 885s & Dakars riding on 33" KM2s
    265/70/16's will be the same height but wider than stock (speedo and odo will be correct). Check with tire manufacturers but I believe 265 is the widest you can put on a 7” rim. Not sure what size rims your PreRunner has.
  8. Jul 30, 2011 at 9:46 AM
    Sandman614
    Sandman614 Travis #hotsavannahdotcom, LRGRNR
    Tim
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Fixed.
    I am running 265/75/16 and am having no issues scrubbing.
  9. Jul 30, 2011 at 1:46 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    scrubbing ... I love it.
    I believe 4Wheelin4banger has it right... you can't fit much bigger tire on the 7W rims. On that note, I got my tires a day before I got my rims, and its not a solid feeling running larger tires on the stock rims. I don't recommend it any bigger than you are.
  10. Jul 31, 2011 at 9:34 AM
    4Wheelin4Banger
    Randy
    ^:jerkoff:^ Real helpful. I can only imagine where you can fit 355's with room to spare.
    Thanks for only thinking of being a :jerkoff:.
    I thought TW was a place to turn to for answers to questions when you need help. And you return the favor by helping others when you can. Not open mike night at the Laugh Factory. I could be wrong but that's why I come here.
  11. Jul 31, 2011 at 10:59 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Actually you screwed it up, the other poster had it correct. A 265/70R16 is the same height as the OP's original 245/75R16. Your 265/75R16's are taller. Don't believe me, check it out...
    http://www.tacomaworld.com/forum/tirecalc.php
  12. Jul 31, 2011 at 11:01 AM
    Pugga
    Massachusetts
    The OP looks to have the same rims as the TRD off road and a 245 series tire. The TRD Off Road has a 265 series tire so why would it be a bad thing to up to the same size that comes stock on another Tacoma package with the same wheels?
  13. Jul 31, 2011 at 12:19 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    If MPGs are a concern expect to lose 2 MPG going to 265/70/16.Wider tires create more drag.
  14. Aug 1, 2011 at 10:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    In theory yes, but my experience was no noticable mpg loses after upgrading from a 245/75 to a 265/70-16.
    OP, just a confirmation that the 265/70 is about the same height as the 245/75, just a tad bigger. You can also fit a 265/75-16 in there without any rubbing. A bit taller tire, fills the wheel wells better to.
  15. Aug 1, 2011 at 10:56 AM
    Pugga
    Massachusetts
    Part of the reason people are showing losses when going from the 245 to the 265 is the tire itself. People are swapping out the light, narrow Dunlop for a heavier tire with a more aggressive tread pattern. All factors combined will determine how much you might lose (as Lurkin mentioned, you might not lose any MPG's).
  16. Aug 1, 2011 at 11:25 AM
    BmanDad
    BmanDad Well-Known Member
    :popcorn:
  17. Aug 1, 2011 at 11:37 AM
    Pugga
    Massachusetts
    It was a rhetorical question... Nothing to see here, move along :cool:
    I know what he was getting at, if you have a narrow rim that was made to accept a 245 series tire, you shouldn't go up to a 265, it can cause issues. It'll work, but it's not the best set-up. The tire hangs over the rim too far but in the OP's case he's got the rims that were released from the factory with 265's on a different model so there's no harm in upsizing.
  18. Aug 1, 2011 at 12:09 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    265/70/16
