Tire won't move?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mistaare, Mar 26, 2014.
  1. Mar 26, 2014 at 3:41 PM
    mistaare
    mistaare [OP] Well-Known Member
    silver. sport.
    Got new rims. Just removed center cap and lugs and tire/rim won't budge? Any ideas how to get it off?
  2. Mar 26, 2014 at 3:42 PM
    Aw9d
    Aw9d That one guy
    Is it hitting the brake caliper?
  3. Mar 26, 2014 at 3:43 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Take a mini sledge and hit the tire from the inside. Probably rusted on a little.
  4. Mar 26, 2014 at 3:46 PM
    mistaare
    silver. sport.
    Ok not hitting calipers. I will try sledge. Tires were rotated by garage about 1000 miles ago and lugs were on there REAL tight
  5. Mar 26, 2014 at 3:47 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    This. It sometimes just need a little help. Just make sure you hit the tire and not the wheel/rim.
  6. Mar 26, 2014 at 3:50 PM
    mistaare
    silver. sport.
    Just beat the shit out of it with rubber mallet. No luck.
    Dammit.
  7. Mar 26, 2014 at 3:52 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Hi,
    I understand that you are taking off the old wheels and tires to have the tires mounted on the new ones, correct? If so the wheels have corroded to the drum and disk. Replace a lug nut or two loosely and then whack on the tire sidewall with a BFH or mall to break it loose. They can be fairly tenacious.
    When you put the new wheels on the vehicle smear some anti seize on the matting surface of the drum and disk.
  8. Mar 26, 2014 at 3:53 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    give it a swift kick from the inside if you can. sitting down on your ass, and heel to the tire.
    if that doesnt work get some liquid wrench or some type of lubricant and spray it in all the holes and on the back side of the wheel where it seats at.
    if that doesnt work, kick harder. lol
    Edit: when i say swift, i mean kick that fucker hard!!
    think about what your front end goes through, giving her a nice hard kick wont do anything wrong
  9. Mar 26, 2014 at 3:55 PM
    Aw9d
    Aw9d That one guy
    :rofl:
  10. Mar 26, 2014 at 4:08 PM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    This!
  11. Mar 26, 2014 at 4:22 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Could even put a few of the lug nuts back on loose then lower the jack just a hair... use the weight of the truck to break it.
  12. Mar 26, 2014 at 4:28 PM
    OutbackHack
    OutbackHack Well-Known Member
    Evergreen, CO
    2014 DCLB Heavy
    Stupid amount of extra heavy metal all over
    This is the best way I've found. Loose the lugs so they're a little less than finger tight while the truck is still on the ground. Then push or rock the truck a bit before jacking it up.
    Huge amount of low speed force while the truck is safely on the ground as opposed to hitting it with a sledge hammer or kicking it while your truck is balancing on a jack.
  13. Mar 26, 2014 at 4:29 PM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    dont be afraid to beat the hell out of it.
    and you dont need to kick it from the inside. you can do the same work from the outside where its 1.) safer and 2.) you have more room to work and swing and kick. its pretty common to get them wedged on there after a while. just give it some love.
    and the brute force method.
  14. Mar 26, 2014 at 4:31 PM
    4runnercaged
    cody
    arizona
    LOL
    never thought of that. great idea
    dont damage your wheels though!
  15. Mar 26, 2014 at 4:41 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    This -----KICK IT!!!!!!!!!
  16. Mar 26, 2014 at 4:45 PM
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
    Ill be damned if this didnt happen to me the other day while i was waiting in the parking lot to meet some clients i helped some lady change her tire and her tire wouldnt come off....i looked like an idiot standing there kicking the dog crap out of it. Needless to say it didnt work so i took a pair of wiremans pliers with a chisel end and stuck it between the drum and the rim and gave it a swift push and it came right off.
  17. Mar 26, 2014 at 4:49 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Ahhh yes, a stuck rim. Beat the hell out of it and then do it the other way with the jack and then get really pissed because it's 6:30am, cold and rainy, you're late for work, grab your cell phone and call out, start calculating how much air you have to put in to get to the local tire guy. Then hand it off to him and when you pick it up, listen to the old guy tell you his guys worked on it for an hour or two trying to get it off. What I am saying is, good luck.
  18. Mar 26, 2014 at 5:15 PM
    Jdaniel1274
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    This is a good idea!
  19. Mar 26, 2014 at 5:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe loosen the lug nuts a few threads then start the truck and move it a few inches while turning the steering wheel. Don't loosen them too much!
  20. Mar 26, 2014 at 5:55 PM
    mistaare
    silver. sport.
    ALL FOUR F'ing tires have been seized!!! I am on my last one and I CANT GET IT TO BUDGE!!! I have sprayed the crap out of all of them with wd40 and have had to drive the truck back and forth to get them to break (finger tighten two lugs)but I can't get this last one to break loose!!!
    Grrrr I want to kick some kittens
