Tire won't move?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mistaare, Mar 26, 2014.
  1. Mar 26, 2014 at 5:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    bottle jack between frame rail and tire.
  2. Mar 26, 2014 at 6:11 PM
    mistaare
    mistaare [OP] Well-Known Member
    silver. sport.
    Just drove up and down st with lugs finger tight and still WONT BUDGE!
    Thanks a ton for all the quick reply's
  3. Mar 26, 2014 at 7:56 PM
    mistaare
    silver. sport.
    After four hours, and four seized wheels I won the battle with three, gave up on the last one. Any other ideas lets here them. I need to source a bottle jack.
  4. Mar 26, 2014 at 8:04 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    How big of a hammer are you using? An 8 lb sledge against the sidewall of the tire is ideal if the wheel really stuck (be carefull of the rebound), with a steady hand to swing it of course. When you apply the anti-seize compound, only apply it to the pilot portion of the hub, not the hub face of the rotor or drum. Applying it to the face can cause loose wheels and sheared studs, and the seizing happens at the pilot area anyway.
  5. Mar 27, 2014 at 10:32 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    wow that sure is crazy. i hope you got it off. that would royally piss me off.
    at this point id try the bottle jack method.
    thank god for me living in arizona. haha
  6. Mar 27, 2014 at 10:39 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Another good reason to get the tires rotated on a 5K schedule.
  7. Mar 27, 2014 at 10:40 AM
    4runnercaged
    cody
    arizona
    LOL
    tires were rotated 1000 miles ago.
    how long ago were they rotated?
    it makes me think they didnt tighten the lugs in a star pattern or something.
  8. Mar 27, 2014 at 10:45 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Make sure to pick up some Never seize and put on the mating area so this wont happen again.
  9. Mar 27, 2014 at 10:59 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    take it out on pavement, drive about 10 mph spike the brakes. may take a couple trys, make sure lugs are little tighter then fingure tight, just use 3 lugs.
  10. Mar 27, 2014 at 11:13 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    use a long prybar from behind. If it is a front tire then pry on the rim using the ball joint as the anchor.
