Tired leaking CV assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by b00ts, May 31, 2012.
  1. May 31, 2012 at 3:21 PM
    b00ts
    b00ts [OP] New Member
    Boots
    Tumbleweed, Arizona
    sr5 4x4 TACO!
    mountain-checking bruises, crosswind stabilization perforations, and good old arizona pinstripes.
    Candi(my truck) is leaking on the front right cv assembly. I've seen some of the threads about repair, however, I can't rebuild it til' saturday tho. Should I not drive it, or will be aight goin 50 miles? Basically don't want to make it a more expensive repair than it's already gunna be.
  2. May 31, 2012 at 5:36 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Grease or gear oil? If its grease and its just oozing out of the boot you are fine, replace the boot of CV when you get a chance. For a temporary fix, squeeze the boot clamp with a pair of dikes to make it tighter. If it's gear oil, make sure the diff is at the full level and order a set of seals.
