Tired of 5100's Options ?
Discussion in 'Suspension' started by intense, Feb 26, 2011.
  1. Feb 26, 2011 at 6:52 AM
    intense
    intense [OP] Well-Known Member
    Georgia
    TRD OFF ROAD '07
    ASE Dry, Carbon filter removed, Grillcraft, 5100's. Low Pro Ameriweld box black powder. Tint / Vent Visors. Textured Black skid plate. Husky Liners. Design Seat Covers
    Bought this 07 DC 4x4 Off Road that has 5100's the front are set high as possible, they squeak, and the truck rides like a log wagon. What can i replace this junk with, that will lift, level, and ride better ? Killin' me.
  2. Feb 26, 2011 at 6:53 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    set the bill's at zero and install ome 885 coil.....3 inch lift
  3. Feb 28, 2011 at 1:12 PM
    intense
    Georgia
    TRD OFF ROAD '07
    OME 885 coil will work with stock strut nothing else needed just the OME coil and the front will get 3" lift ?
  4. Feb 28, 2011 at 1:13 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    might need a small topplate spacer but otherwise yes
  5. Feb 28, 2011 at 1:15 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    IMO just buy the Toytec OME 3" lift. I have it and love it....
  6. Feb 28, 2011 at 2:34 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    They wll, but they will ride terribly because the stock shock is not valved to properly dampen the stiffer spring.
    I'd use the billy's @ zero in conjunction with the 885's.
  7. Feb 28, 2011 at 2:37 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    sorry about any confusion but i thought the OP meant the 5100 with the 885s not stock strut/shock
  8. Feb 28, 2011 at 3:05 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    OP stated he has Bilstein 5100s. I believe he does because he mentioned having them at the highest setting. Stock shocks can't be adjusted. Either that or the OP has done something he's not telling us about.
    You've got a couple options, you could keep the Bilsteins and add a different coil like mentioned above. The 885 sounds like it would do what you're looking for. The Eibach coil with the Bilstein 5100's set at .85 would work also but might not get you all the way to 3". Another route is to go with a completely new set-up like the OME kit or one of the adjustable coilover set-ups.
  9. Feb 28, 2011 at 3:12 PM
    KPT
    09 Prerunner
    Correct but I was just clarifying because he specifically used the phrase "stock shocks"...well "stock strut" actually.
  10. Feb 28, 2011 at 5:37 PM
    intense
    Georgia
    TRD OFF ROAD '07
    Sorry for all the confusion. The truck is stock except for the 5100's ( back breakers ) looking for economical alternative that will fit without complications, want to lower front shocks but still have 2-3 inch lift. Just want it to ride better.
  11. Feb 28, 2011 at 5:46 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    02 4runner 04 solara
    4runner-32x11.5x15 falken rocky mt, tundra king 2.5 coilovers with taco perch, TC UCA, OME rear springs and procomp es9000's, thule roof rack.
    then springs and billys at 0 would work best.
  12. Feb 28, 2011 at 6:45 PM
    intense
    Georgia
    TRD OFF ROAD '07
    OME 885's ?
  13. Feb 28, 2011 at 6:50 PM
    Pugga
    Massachusetts
    To maintain the 2-3" of lift, 885's would be a good option for a double cab.
  14. Feb 28, 2011 at 7:28 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I don't see why you guys are telling him a higher spring rate spring will ride better.
    The truth was spoken long ago -- if you want a stock ride, restore the stock ride height.
  15. Feb 28, 2011 at 7:32 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Although, you don't tell us WHERE the ride is rough.
    If you're talking about on the street, my advice stands.
    But if you're trying to improve the ride in high speed off road situations, well then you have a variety of options. But you'll have to do the rear also.
  16. Feb 28, 2011 at 7:45 PM
    intense
    Georgia
    TRD OFF ROAD '07
    Thinking restore stock shocks, add a toytec 3". These 5100's got to go besides, a friend did the same with stock and the truck rides great !
