Tired of searching and researching, looking for a definent answer!
Discussion in 'Suspension' started by drewgbrown, Dec 17, 2014.
  1. Dec 17, 2014 at 8:27 PM
    drewgbrown
    drewgbrown [OP] New Member
    Drew
    Austin
    2012 base v6
    29.5 tires, bull bar, tool box
    Through mindless hours of researching lifts and kits and what not I am tired of it and just want an answer that maybe yall could provide me!
    If yall could please give me a direct link or something to google that would be great but I am tired of sifting through 20 pages of information for what I want.
    Okay so I want a 3" lift to my entire truck and a front level. I want to buy the 3" as a KIT please!!! This will be going on a 2012 4x4 tacoma with 30.5" tires.
    I will be getting the lift and align done by a secondary company. This lift is primarily for show but will be seeing decent off road use of mudding and off roading 6-10 times a year.
    So to sum it up if anyone could give me a direct link to a 3" lift and level kit that is good for decent off road and still good for city driving that would be super helpful. Thank you!!!
  2. Dec 17, 2014 at 8:36 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
