Tired of Tacoma problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lynlan1819, Apr 3, 2017.
  1. Apr 4, 2017 at 6:19 AM
    #101
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Resale value only matters when you sell.
    I don't buy vehicles with the idea I'm going to sell them.
    Plus I heavily mod vehicles, which means resale value will always be astronomically below what I put in lol.
    Plus I'm not going to buy a vehicle I'm not happh with just because one day I can sell it for a good price. Makes no sense.
  2. Apr 4, 2017 at 7:14 AM
    #102
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    My 2010 with 87k miles has had the following work done since I bought it new:
    - Rear leaf springs replaced twice under warranty (TSB springs in 2010 and recall springs in 2016).
    - Gas pedal TSB at 13k miles under warranty.
    - Manual transmission pilot bearing replaced under warranty at 57k miles due to chirping noise TSB.
    - Clutch replaced at 58k miles due to failed clutch disc spring; split the cost with dealer.
    - Driver's side A/F sensor replaced at 79k miles in 2016; did the work myself.
    - Interior water leak from HVAC unit at 75k miles; fixed with putty because I didn't want to spend $1000+ on replacement.
    I've been experiencing the chirping noise from the blower motor for a few years now and I just live with it. I'm going to take it apart and grease the motor when the weather warms up.
    On the bright side, my front brakes are finally shot at 87k miles. I've had the replacement rotors and pads for months but I need to get the damn slide pins removed from the calipers.
    Probably fewer repairs than the average vehicle but more than I would expect from a Toyota, let alone a Tacoma.
  3. Apr 4, 2017 at 7:15 AM
    #103
    MolonLabe916
    MolonLabe916 New Member
    05 Tacoma prerunner V6
    3" lift, exhaust, intake
    05 tacoma prerunner 311,000 miles. Oil changes, spark plugs, battery 3 times, belts 1 time, rotors 2 times. Usual stuff. Other than that, not a single issue.
  4. Apr 4, 2017 at 11:01 AM
    #104
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    I don't regret purchasing it but I feel like all I do is bitch about it. I wish Toyota would have done some things differently so that everyone's faith in them would've been more warranted. If you look you can already see posters who have post-purchase rationalization and attack anyone who has the gall to mention their problems with "you should just go buy a prius/raptor/ridgeline" or "it's a truck not a car".
    Well. Here are my complaints over 4 years:
    • MPG (partly my driving style, but still should be better).
    • Seating position too high (did the rear-view mirror mod, dealt with it)
    • Blower motor buzzing and grinding (replaced with TSB version)
    • Vibrations at 45mph (replaced needle bearing with the ECGS version)
    • Vibrations at >60mph (replaced the carrier bearing)
    • Water intrusion (finally fixed after re-sealing back window/3rd brakelight)
    • Timing chain cover oil leak TSB (over $1k, will have to be done again some years later)
    • Vibrations at >60mph (replaced U-Joints)
    • Master Brake light (intermittent problem... no other symptoms)
    • Vibrations at >60mph (broken rear flange yoke, drive shaft literally fell off)
    • Vibrations (repaired/re-balanced driveshaft and replaced carrier bearing again)
    TRDSport10 and fla_sun like this.
  5. Apr 4, 2017 at 11:41 AM
    #105
    MolonLabe916
    Seems like people with the same year and model taco have similar issues. I've been looking to upgrade to a newer model. But this thread has me thinking.
    Between 2010 to current, which year taco has had the least amount of issues?
    Maybe that question should be it's own thread? :notsure:
  6. Apr 4, 2017 at 12:11 PM
    #106
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    I kind of regret getting the 3rd gen, the FR-S it replace was a much better vehicle, but not the 2nd Gen.
  7. Apr 4, 2017 at 12:23 PM
    #107
    THROTTLE231
    THROTTLE231 Well-Known Member
    Shane
    High Dez,Comifornia
    2011MGMDCSB6MT With Not So So Cool Shit...
    I LIKE BEER....
  8. Apr 4, 2017 at 12:37 PM
    #108
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I agree, I was speaking to the fellow who posted this:
    We keep our vehicles 'til the wheels fall off, and then put them back on and drive some more. My wife holds the record with an '89 Celica we bought new and drove for 425k miles, it still looked pretty good and ran fine when sold in 2003...
    1Shifter likes this.
  9. Apr 4, 2017 at 12:41 PM
    #109
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    C'money Shane...1 more post and ya hit a thousand
    Nice P40 :thumbsup:
  10. Apr 4, 2017 at 2:00 PM
    #110
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    140,000km in a short 3 years, done all my own maintenance minus the transmission flush because I did not have the machinery. Not one issue.
  11. Apr 4, 2017 at 2:13 PM
    #111
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    No trouble with my 2012.
    Stock stereo still sucks donkey balls and I'm still too cheeep to replace it. LOL!
    1Shifter and txmxer like this.
  12. Apr 4, 2017 at 2:21 PM
    #112
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    ^ This. I don't understand the whole resale value thing when buying a vehicle. I know a lot of people don't keep their vehicles that long, but for me resale value had 0 effect when getting my Tacoma. Reliability had everything to do with it
    Hairy Taco likes this.
  13. Apr 4, 2017 at 3:01 PM
    #113
    THROTTLE231
    Shane
    High Dez,Comifornia
    I LIKE BEER....
    haha...It just happened on another thread...I did not realize it... and then it was too late..Felt like we should have shared it together:D :hattip:Nice B24:cheers:
    1Shifter[QUOTED] likes this.
  14. Apr 4, 2017 at 3:12 PM
    #114
    cliffyk
    Cliff
    Saint Augustine, FL
    That is why Toyotas in general, and Tacomas in particular, have high residual value--wanna' see depreciation look at Chrysler products.
    We bought my wife's '03 Highlander in late 2006 with 85k miles, it just turned 215k (with regular fluid changes, timing belt, plugs, etc.) and runs like new--I'd leave in 5 minutes drive it anywhere...
  15. Apr 4, 2017 at 4:15 PM
    #115
    1Shifter
    Jeff
    09 PreRunner
    Thanks Buddy...I wish it was a B24 but you're close, it's a B25. Beautiful aircraft.
  16. Apr 4, 2017 at 4:27 PM
    #116
    THROTTLE231
    Shane
    High Dez,Comifornia
    I LIKE BEER....
    Ahhh The "Mitchell" Yes it is a Beautiful bomber. I want a ride if its yours:D
  17. Apr 4, 2017 at 4:40 PM
    #117
    1Shifter
    Jeff
    09 PreRunner
    I wish it was my friend! I caught it taxiing at an "undisclosed location" and I'm a huge fan of aircraft, particularly WWII aircraft. I couldn't resist taking a few pics, pilot even waved at me from an open cockpit window.
    THROTTLE231[QUOTED] likes this.
  18. Apr 4, 2017 at 4:50 PM
    #118
    1Shifter
    Jeff
    09 PreRunner
    She's Purdy...
  19. Apr 4, 2017 at 4:53 PM
    #119
    THROTTLE231
    Shane
    High Dez,Comifornia
    I LIKE BEER....
    Very cool... I've only seen one in a Museum, and with only less then 50 still Airworthy I bet that was killer to see in person. I work on modern aircraft's for a living (with no pilots) but would trade it in a heartbeat to turn wrenches on a P51 or P40.:plane::oldglory:
  20. Apr 4, 2017 at 4:57 PM
    #120
    THROTTLE231
    Shane
    High Dez,Comifornia
    I LIKE BEER....
    :drool::drool::drool::drool::drool::drool:
