tires and rim exchange
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgank, Sep 27, 2010.
  1. Sep 27, 2010 at 1:47 PM
    wolfgank
    wolfgank [OP] Member
    tony
    virginia
    04 silver Prerunner SR5 Xtracab
    will 06 prerunner 17 rims work on a 04 prerunner and what is the biggest tire i can use with stock suspension? thanks FNG
  2. Sep 27, 2010 at 1:49 PM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
    265/75 will be the biggest tire.
    the rims should work as well.
  3. Sep 27, 2010 at 9:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The 2nd gen sport wheels will mount but they will tuck in about 9/16th of an inch further that the stock '04 alloys. 265s are the widest tire that wont rub.
