Tires and wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cleeh24, Jan 25, 2020.
  1. Jan 25, 2020 at 8:15 PM
    Cleeh24
    Cleeh24 [OP] Active Member
    04 Tacoma Dblcab prerunner
    Double din stereo/backup camera/ speakers
    Kind of a noob when dealing with this kind of stuff. I want to run 285/75/16 on my truck with a 3 inch front and 2 inch rear leveling kit. Can I run those tires on my stock wheels or will I have to upgrade? If I have to upgrade, any recommendations and what wheels I should get? Something not too pricey. Thanks in advance
  2. Jan 26, 2020 at 1:29 PM
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    i bet they'll rub. i ran 265/75/16 on my stock height truck and they rubbed the frame on stock wheels at full lock. the lift sounds like more than necessary to clear xxx/75/16s but the wider tires may require spacers. i don't like or trust wheel spacers. why do you want the wider tires?
  3. Jan 26, 2020 at 9:18 PM
    Cleeh24
    What about a wheel with negative offset? I suppose I can go with 265 but main reason is for looks, Like a more aggressive look I guess.
  4. Jan 26, 2020 at 11:07 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Take a look at:
    https://adventuretaco.com/what-size-tires-fit-my-lifted-tacoma/
    and then this -
    Not sure if you'll get away with your stock UCAs. Maybe, maybe not. Wheel and backspacing/offset will come into play as well.
    Take a look at those two threads - good info there.
    Cleeh24[QUOTED][OP] likes this.
