Tires as truck height question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vram74, Apr 19, 2016.
  1. Apr 19, 2016 at 6:28 AM
    vram74
    vram74 [OP] Well-Known Member
    05 Prerunner SR5
    My truck currently has 265-60-R18's. How much difference in cab height would I see (if at all) if I dropped to a 245-75-R16?
    I'm thinking of putting the stock steel rims back on due to a $200 price difference in tires. I'd actually like my truck a bit lower as I have to hop a bit to get in it now.
  2. Apr 19, 2016 at 6:34 AM
    Pigpen
    Dan
    Northwest Montana
    Use the tire size calculator. Its at the bottom of the page if you're on a computer, or look for it using the search function. The cosmetic difference will be big, but overall height will change very little.
    Ha ha, apparently it links in the post auto magically when you type it!
    ChadsPride likes this.
  3. Apr 19, 2016 at 7:02 AM
    vram74
    05 Prerunner SR5
    Thanks for that link. It's pretty much a wash heighth-wise.
    Is there a way to lower a prerunner about 2-3" without any major modifications? Please excuse my ignorance. I'm a complete dumbass regarding this stuff.
