Tires by Weight
Discussion in 'Wheels & Tires' started by Slashaar, Sep 18, 2018.
  1. May 4, 2020 at 3:00 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Cooper AT3/4S is pretty light:
    255/70R17 is 41 lbs
    255/75R17 is 39 lbs.
    285/70R17 is 46 I think.
    Slashaar[OP] likes this.
  2. May 4, 2020 at 3:02 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    E load range tires are likely to be overkill for Tacoma on the road, because our trucks aren’t that heavy. I can attest to decreased fuel economy, harsher ride, and increased noise when going from stock OR tires to E rated mud terrains. This is partly why I plan to have a second set of P rated tires for daily driving. I like the increased height, so I wish I could find a P rated 33”.
  3. May 4, 2020 at 3:08 PM
    gudujarlson
    Minnesota
    That’s the rub. Tire manufacturers do not publish the info; not even for bicycle tires. It generally requires a altruistic individual with the proper equipment, knowledge, and wealth to test the tires. However, I do think in theory that a P rated tire will generally have less rolling resistance than a E rated tire due to the extra material on the E rated. This has been more or less the general rule of thumb for bicycle tires. Low rolling resistance road race tires are thin and fragile compared to commuter tires.
  4. May 4, 2020 at 4:36 PM
    Slashaar
    Slashaar [OP] Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Yeah, but I like the extra layers just because I offroad my truck and would rather not blow a tire out on the trail!
  5. May 4, 2020 at 4:47 PM
    aaronPRO19
    aaronPRO19 Well-Known Member
    Aaron
    Santa Barbara, CA
    2019 TRD Pro
    OV Tuned w/ catted dump tubes, 4.88 Nitro Gears, RCI Skids, Shmellfab Sliders,
    I would compromise and take an 8 ply.
  6. May 4, 2020 at 4:49 PM
    aaronPRO19
    Aaron
    Santa Barbara, CA
    2019 TRD Pro
    If only they made it in a 16.
  7. May 4, 2020 at 4:49 PM
    Slashaar
    Josh
    Kansas City, MO
    added to OP.
