Tires chirp while hitting the brakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Superman, Jul 5, 2018.
  1. Jul 5, 2018 at 5:28 PM
    Superman
    Superman [OP] Well-Known Member
    Joe
    Michigan
    2017 Quicksand TRD OR DCSB
    Current: Behind rear seat MOLLE panel Softopper Empyre grille insert MesoJDM ultimate red maps MesoJDM ultimate white dome Future: BajaRack roofrack/basket Mobtown bolt-on sliders Mobtown rear plate bumper Mobtown front plate bumper On-board air compressor Ditch lights LED headlights (blacked out) LED taillights (blacked out) LED yellow fog lights Bedrack over softopper Maxtrax
    I know the combination of low weight in the rear, and the weight transfer under medium-heavy braking can make it easy to lock up the rear tires (especially on uneven Michigan roads). I never go 100% brakes unless I'm avoiding a collision. When I drove my last car I would often downshift to keep the tires from locking up
    A few times now while I was stopping for a yellow light, I've noticed my tires chirping a bit.
    Is this normal? How sensitive should my ABS be, should it be preventing this short lock up?
    • 5k miles on truck
    • Tires show no signs of feathering or uneven wear
    • Stock '17 OR
    • Tire pressure: 36 psi
    • Asphalt temp: unknown
    • Outside air temp: 90°F
  2. Jul 5, 2018 at 5:37 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Doesn't sound normal to me, unless your jumping on the brakes.
    Oh and it's also not normal to stop at yellow lights, :bikewheelie2:
    tacoguy88, kgilly, shakerhood and 2 others like this.
  3. Jul 5, 2018 at 8:45 PM
    Superman
    Joe
    Michigan
    Thanks, might have it looked at
    Lol yeah, its a quick yellow I always catch on my way to work :p. Cross traffic is usually speeding gravel trucks, so I'd rather not take my chances
    Spare Parts[QUOTED] likes this.
  4. Jul 5, 2018 at 9:32 PM
    AverageGuyTaco
    AverageGuyTaco Well-Known Member
    2017 TRDOR-DCLB
    The brakes on my 2017 ORLB are super sensitive. Its not my daily driver so every time I get in it, I have to get use to how sensitive the brakes are. I have had similar situations where I swear the rear end locked up momentarily. At my 5000 check I asked them to check the brakes. They found nothing wrong.
    Superman[OP] likes this.
  5. Jul 6, 2018 at 6:28 AM
    Spare Parts
    Southern Maine
    Don't the OR have a brake booster or something like that? Guess it's working.
  6. Jul 6, 2018 at 6:39 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I think it's for Crawl/MTS etc., I don't believe it does anything during normal driving, but I could be wrong.
    OP, in a similar thread a couple weeks ago with screeching tire's around corners, that OP took a look at his tires and they were completely bald on the inside prematurely. It had to do with a bad alignment. May be worth looking at them closely. He didn't have very many miles on the truck if I remember correctly.
    Edit. I see you addressed the tire comment, disregard.
  7. Jul 6, 2018 at 6:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    What's the number in the door jamb? Start there, then do a series of chalk tests to arrive at the proper pressure for your tires/truck.
    If you don't know what a chalk test is, Google is your friend.
    While unlikely to impact the concern in your post (but it might) it will at least be sure you are at the right PSI.
