Tires.com / Nitto Terra Grapplers QUESTION
Discussion in 'Wheels & Tires' started by RSH904, Jun 25, 2010.
  1. Jun 25, 2010 at 9:53 PM
    RSH904
    RSH904 [OP] Well-Known Member
    Akron, Oh
    Red and Black Attack
    Extang Trifecta Tonneau Painted Stock Wheels De Badged Yellow Fogs AVS Bugflector II UWS Running Boads Hunter Bully Bar HD Satoshi
    Ok im getting ready to replace the tire on my 07 base 4x4 for the first time. I have the stock steelies (although painted) As best I can tell I should be able to jump from the 245/75/16 Dunlaps to the 265/75/16 Nitto Terra Grapplers without any problem. Am I correct in this???? Also Ive done some shopping and am probably going to go with tires.com.
    1. They are trying to see me tpms rebuild kits/ I dont think I need these right? I have had the tires broken down twice now and never needed that.
    2. Will I need to replace the valve stems? I cant remember I did this when I had the tires remounted after the wheels were painted.
  2. Jun 25, 2010 at 9:55 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yes you can fit those fine
    Im not sure but I don't think you need a rebuild kit
    You do not need to replace the valve stems
  3. Jun 25, 2010 at 9:56 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    cant replace valve stems because as far as i know the tpms is on the valve stem. so its one assembly
  4. Jun 28, 2010 at 6:46 PM
    RSH904
    Akron, Oh
    OK, another Question about the Nittos. Right now I have the stock Dunlaps 245/75/16. I thought that I would just go with the 265/75/16 Terra Grapplers (they are not made in the 245- you have to to wider). I was pricing them at NTB and they told me that It would propably be better to go with the 265/70/16 Terra Grapplers to keep the ratio much closer and not have to recalibrate the speedo. Anybody know anything about this? Is this true????
  5. Jun 28, 2010 at 7:11 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    If you go the top of this thread and use the "Tire Calculator" you will find answers to ALL of your ????
    What the difference between the 245's PLUS the 265 comparisions will open your eyes too...
  6. Jun 28, 2010 at 7:22 PM
    silver streak taco
    silver streak taco Well-Known Member
    why dont u get ur tires at discount tire... they beat any price u find... about the tpms: tpms sensors can be rebuilt with a rebuild kit and it replaces the rubber gromet, washer and the screw down top piece that holds it all together and the reason for rebuilding them is just like replacing a valve stem because the parts do fail eventually. fyi- i am a part time discount tire employee going on 2 years
  7. Jun 28, 2010 at 7:28 PM
    silver streak taco
    sorry didnt read post carfully ur already getting tires at discount tire
  8. Jun 29, 2010 at 5:34 PM
    RSH904
    Akron, Oh
    Wow that is pretty awesome. Great tool. The 265/70/16 are pretty close I guess. At 65 MPH I will only be off by about 1/3 MPH.
