tires dont fit my current set-up
Discussion in 'Wheels & Tires' started by boxpup1971, May 22, 2012.
  1. May 22, 2012 at 11:54 AM
    boxpup1971
    boxpup1971 [OP] Member
    Cooger
    North Port,FL / Morgantown,WV
    09 blk tacoma sport
    3" Pro Comp suspension lift
    Im currently running 305/60R18s on 18x9 monster XDs with no problem in the rear, my problem is occurring up front. I have a 1/4" spacer in place and tires are still rubbing on upper control arm and on frame below lower control arm.I need smaller tires and dont know what size to get or if thats even the route i should take??????????? PLEASE HELP.
    thanks so much.
    cooger.
  2. May 22, 2012 at 12:08 PM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    I would get bigger spacers up front. Like some spidertrax 1.25".
  3. May 25, 2012 at 6:53 AM
    DevL
    DevL Well-Known Member
    You also have a problem in the rear. If you offroad and stuff one rear while drooping the other you will rip off your fender flare.
  4. May 25, 2012 at 6:57 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    1) who told you 305's would fit?
    2) they will always rub regardless of what you do
    3) your only fix is to get new tires or start hacking sheet metal (fenders) and your bumper.
  5. May 25, 2012 at 7:00 AM
    DevL
    First your tires are for a spindle lifted 2 wheel drive or drop bracket 4x4. Second what are your backspace measurements? You need an aggressive cab mount chop... not just the BAMF cab mount chop plates, hammer pinch weld about 9" up and do some extensive cutting to get even close to fitting those. You likely need new UCA as well. Only the Light Racing uca is not going to stuff the eheel even further into your frame.
  6. May 25, 2012 at 7:24 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    X2
  7. May 27, 2012 at 6:14 AM
    boxpup1971
    Cooger
    09 blk tacoma sport
    Some clown from 4 wheel parts in tampa told me to purchase the 305/60R18s. The reason i didn't purchase from 4 wheel parts was because i saved over $150 a piece somewhere else. I think he intentionally steered me in wrong direction because i didn't wanna buy from him. I WILL NEVER GO BACK TO THE TAMPA STORE. EVER!!!!!!!!!!!!!!!!!!
  8. May 27, 2012 at 6:20 AM
    boxpup1971
    Cooger
    09 blk tacoma sport
    There is no way I'm cutting my truck up, so i guess i will purchase new tires. Thinking about BFGoodrich all terrain 285/65R18s but i still don't know if that will fix problem??????????
  9. May 27, 2012 at 6:40 AM
    boxpup1971
    Cooger
    09 blk tacoma sport
    some clown from 4 wheel parts told me the wrong tire size
  10. May 27, 2012 at 6:46 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    You have to take some blame in this too. You need to do your research before you start throwing money around. If you would have spent some time on here looking at what tire sizes work, and what would be involved with larger sizes you wouldn't have this problem.
    And on a side note, how did he know you wouldn't be buying from him?
    Frank
  11. May 27, 2012 at 7:26 AM
    boxpup1971
    Cooger
    09 blk tacoma sport
    you're correct, all the blame shouldn't be directed at him. I wish i would have taken the time cause its gonna end up costing me a ton more money. Lesson well learned.
    and to answer your side note......... because i was up front with the guy and told him my intentions!!!!!!!!!!!!
  12. May 27, 2012 at 7:30 AM
    Highland Logan
    Frank
    Nova Scotia, Canada
    Glad to hear you have some broad shoulders.:thumbsup:
    Frank
