Tires for 2.7L 4-cyl 5 speed
Discussion in '1st Gen. Tacomas (1995-2004)' started by DCoyle516, Aug 17, 2022.
  1. Aug 17, 2022 at 6:59 PM
    DCoyle516
    DCoyle516 [OP] New Member
    David
    1996 Toyota Tacoma
    Currently have 265/75/16s on my 1996 tacoma. It’s a 2.7L 4-cyl with a 5 speed manual. Have had these tires since i bought it so not sure what the power difference from stock tires are… Was hoping to size up to 285s since i got a 2” lift, but not sure if 285s would be too much of a decrease in power to where I’d have to regear…
  2. Aug 17, 2022 at 7:37 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I think it depends on where you live and drive. Live in a mountainous region you're gonna want to regear. Live in Kansas, you'd probably not have to worry about it. ;)
  3. Aug 17, 2022 at 7:49 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    What gear ratio do you have?
    If you have 4.10’s you’ll be ok, not great, but ok.
    Stay away from E-Rated tires. C-Rated is where you want to be. Less options but much lighter and will ride much nicer.
    I’m swapping to some KO2 32x11.50’s on mine. Which are a little bit taller than my current 265 KO2’s.
  4. Aug 18, 2022 at 4:11 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I ran 33x10.50s for years on my 2.7 5 spd with stock 4.10 gears. Worked fine on the pavement, but was a bit high geared for crawling even in low range. 4 high was pretty much useless for anything other than slick roads.
    Bikinaz likes this.
  5. Aug 24, 2022 at 6:00 PM
    Lex8038
    Lex8038 New Member
    Al
    2008 extended can 4 cylinder tacoma
    Bumpers rack gate lift 32s
    I have 3 in lift with toyo AT 33s ran 4.10 forever sucked on the free climbing to higher altitudes. But ignorance kept me from thinking i had an issue on the trail. Then I regeared 2.88s and added ARB rear air lockers. Completely different truck.
    Now for my one min bitch and wine session- this site sucks for us 2.7l 5 speed tacos. All I read when we ask for proformance help is sell it buy a v6. I love my 4 banger I just wish the Tacoma world would stop treating it like the ugle step child
  6. Aug 24, 2022 at 6:11 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Welcome to my world. Try being a 4 banger and a regular cab. I own an ugly redheaded stepchild. ;)
  7. Aug 24, 2022 at 6:18 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Stock tires are what 10.5in wide? So a 285/75/16 would be 11.2? Would there be any rubbing or does a spacer need to be installed?
