Tires for towing
Discussion in 'Towing' started by Hank_Mille, Apr 17, 2018.
  1. Apr 17, 2018 at 5:35 PM
    Hank_Mille
    Hank_Mille [OP] Well-Known Member
    PNW
    2016 Tacoma Limited
    Vehicle is a 2016 dual cab limited auto V6 and she need new tires...
    Use is 100% on road and absolutely don't care about off-road 'looks'... however, I've been told that for towing, only an AT tire has the strength to handle the load - IDK if that is actually necessary for a Taco that is pulling a relatively light weight trailer/load.
    I see that the Michelin Premier LTX comes in a T and V rating - for towing a dual axle (with brakes and Sumo springs) all aluminum toy hauler trailer - weight loaded with 2 race bikes and gear is about 3,500 pounds, I'm thinking the V rated tire should work fine. But I'm new to this....
    So the question is - will this tire in the V rating hold up to rigors of towing, or do I need something more robust?
  2. Apr 17, 2018 at 6:29 PM
    Indy
    Indy Master of all I survey.
    At means all terrain. It has exactly 0 to do with towing. T and v are speed ratings. Also, nothing to do with towing.
    A 3500 lb trailer should add about 350 lbs to your rear end, basically 1 really fat guy. No special tires needed.
  3. Apr 17, 2018 at 6:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    As long as you tow within the ratings of the truck even OE tires are fine.
    Load rating is what you are interested in though.
    Not tread pattern or speed rating as you asked about.
  4. Apr 17, 2018 at 6:51 PM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    I'm not %100 percent but I think V and T are speed ratings. If your looking for tires solely for improving towing performance Id go with narrow and load range E. Factory tires work well (I towed thousands of miles with them) but the E rating and ability to run 80 psi definatley reduces rolling resistance and makes a difference.
    235 85r16 would be about an inch bigger than stock size and have a few load range E options
    If all I cared about was improving towing performance Id go with 225 75r16 load range E. Low rolling resistance and the smaller diameter would lower your final drive ratio compared to OEM. Unfortunately for me I like big tires:notsure:
  5. Apr 17, 2018 at 9:36 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You don’t need special tires for towing what you’ll be towing. Regular passenger tires will do just fine. If you want something a little more heavy duty with a higher weight rating get a set of LT (light truck) tires.
  6. Apr 18, 2018 at 4:28 PM
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Thanks gents - I appreciate the insight!
    :cheers:
  7. Apr 20, 2018 at 4:41 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    I agree with the above as well.
  8. Apr 25, 2018 at 2:04 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Tacomas do not have the payload or towing capacity to require special load tires.
  9. Apr 25, 2018 at 4:29 PM
    Cnasianfire
    Charles
    Wilmington, NC
    However, you bday want to get load E tires because that's what they come in when you buy many of the AT and mud tires for off road, but I digress
