Tires humming only under load?
Discussion in 'Wheels & Tires' started by Thesandaddict, Jun 29, 2016.
  1. Jun 29, 2016 at 2:29 PM
    Thesandaddict
    Thesandaddict [OP] The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Curious if anyone has seen this issue before. Tried to do some research but only found that the wheel bearings may be going out, with less than 30k on it I find that hard to believe. Just mounted 285/70r17 grabber at2s last week, noticed the humming and wrote it off as an aggressive tire hum, but then I noticed that it was only while on the throttle. If I'm coasting at any speed, it goes away, but once I tap the gas, it sounds like the tires are dragging almost. Any input?
  2. Jun 29, 2016 at 7:36 PM
    Thesandaddict
    Harley
    West Covina, CA
  3. Jun 29, 2016 at 7:39 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Have you checked the wheel bearings? Pretty easy and quick to rule that out. Wouldn't be the first guy to blow some out before 30k.
  4. Jun 29, 2016 at 7:42 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Lifted? Any other recent mods? The fact the sound goes away when you let off the throttle makes me think it's mechanical in some way.
    Drive line angle? Something like that?
  5. Jun 29, 2016 at 8:09 PM
    Thesandaddict
    Harley
    West Covina, CA
    I leveled it a month ago, the sound came once the new tires went on. If the bearings were shot, it would make noise under any kind of movement, as long as the axle is moving the bearings are moving, notnjust under acceleration, correct? I'm taking it to a shop Friday because they screwed up the alignment as well (too much camber) and im hoping this reveals an issue once it's on the lift. I'll check out the bearings regardless (can't pinpoint a side it sounds like it's all 4 tires humming) but was hoping to think of something else.
    Driveline angle shouldn't be off, 2" lift and 33s seems to be a popular set-up, would think someone else would've had that issue too if that were the case
